Old Dec 3, 2023 | 06:05 AM
dedwards0323
Default Re: 20 inch wheels on the xfire?
Originally Posted by Crossfirefan1969
Hello there, I'm new to the forum and was wondering whether you could kindly help in the same issue. I'm planning to swap the stock with 9x20 MMR VP3 all round 20 set. However, mock fitting the rim today in the front end, it seemed quite tight. Do you think it would normally fit with 225/30/20? Many thanks!
I believe folks have stated that the overall diameter of the wheel + tire can't be over 26 inches in the front & 27 inches in the rear otherwise there will be rubbing issues on the Crossfire. Check out this post by amx1397 on wheel & tire combinations that will work on the Crossfire: CLICK
