Old Dec 4, 2023 | 07:39 AM
Crossfirefan1969's Avatar
Crossfirefan1969
Default Re: 20 inch wheels on the xfire?
I would suggest you take a look at this website to get a comparison of the overall fitment of the new wheels & tires vs. the Crossfire OEM setup: CLICK
Below is the OEM wheel & tire setup on the Crossfire.
Thank you, I definitely agree and already have a full idea on the specs you kindly shared. However, my only concern is that the fronts are 9 wide. Added to that, I ordered 25 offsets yet the seller sent me 15s, unfortunately. The question now is if I would go for 225/30/20 with the fronts, wouldn't there be any rubbing surprises and wouldn't the tire flat a bit because of the width of the rim, knowing tha there would be normally an extra 6 mm in the diameter of the new setting in comparison to the stock one. 😊
You may also use the calculator in the link below! https://www.calculator.net/tire-size-calculator.html
