Crossfirefan1969
Thank you, I definitely agree and already have a full idea on the specs you kindly shared. However, my only concern is that the fronts are 9 wide. Added to that, I ordered 25 offsets yet the seller sent me 15s, unfortunately. The question now is if I would go for 225/30/20 with the fronts, wouldn't there be any rubbing surprises and wouldn't the tire flat a bit because of the width of the rim, knowing tha there would be normally an extra 6 mm in the diameter of the new setting in comparison to the stock one. 😊
You may also use the calculator in the link below!
https://www.calculator.net/tire-size-calculator.html
The new setup on the fronts show quite a bit of tire sticking out compared to OEM setup. I don't think I would use that but others more familiar with this hopefully will chime in.
A spacer of 10-15 mm would orient the install of the new wheel & tire much better. OOPS!! New setup already has a positive offset less than the Factory Setup. I wouldn't use these wheels! Wheels & Tires stick out of the wheel well way too much for me! Others with more experience hopefully will provide input
So why did the vendor send a wheel that wasn't per your spec of 25 mm offset?
