Old Dec 5, 2023 | 04:21 PM
Isaacmaple08's Avatar
Isaacmaple08
Default Re: Joying 8.8 with Backup Camera
Originally Posted by type dougie
It is cold here so that car is sitting, I’m in WI. I’d like to hear how you did the TPMS sensor and OBD thing.
Also I was going to do a new amp and speakers have you done that? Any advice?
TPMS was a kit I bought off of AliExpress for $20 came with 4 new sensors but I'd assume if you already have 433mhz tpms you dont need to buy new ones if you know the ID. It has a dongle that plugs into the back of the radio to act as a receiver/antenna for the sensors and shows temp and pressure to the tenth.
OBD2 is just a Bluetooth dongle and torque pro, I had ObdLink MX+ from a previous car and just leave it connected. The Tasker app auto-starts those apps when you turn the car on since when going into fast standby it closes all apps.
New amp and speakers were easy, just plugged into Analog RCAs, but had some alternator noise. Grounding the RCAs helped. The amp I bought was small enough to fit in the existing amp location in the passenger floorboard. The only thing you'll need to do is enable external amp under sound settings on the radio.
Will update more in depth and with links when I'm back home
