Re: ECU Troublesoot
1sweetride
Thanks GannyX.
From your experience, would a skreem fault also remove authorization for spark plug operation?
I can fire the starter, start the fuel pump and engine runs fine. I drive the car daily.
If I can't locate the fault, I can eliminate the working components!
In the process of sourcing a DRB3 scan.
Wayne
What is your location? We try to help as for spark plug operation, it suppose to. I can check any ECUs on my bench, If you want me to check it. I dont mind
