Old Dec 14, 2023 | 09:46 PM
  #45 (permalink)
Esinclair's Avatar
Esinclair
Default Re: programing garage door opener ???
Originally Posted by magneticred
  1. For first time training, press and hold the two outer HomeLink® buttons, releasing only when the HomeLink® indicator light begins to flash after 20 seconds. (Do not perform this step when training the additional HomeLink® buttons.)
  2. Position the end of your hand-held transmitter 1-3 inches (3-8 cm) away from the HomeLink® buttons while keeping the indicator light (dots below House Symbol) in view.
  3. Simultaneously press and hold both the HomeLink® button that you want to train and the hand-held transmitter button. Do not release the buttons until step 4 has been completed.
    Note: Some garage door openers may require you to replace step 3 with the “cycling” procedure noted in the “View Canadian Instructions” section.
  4. The HomeLink® indicator light (dots below House Symbol) will flash slowly and then rapidly after HomeLink® successfully receives the frequency signal from the hand-held transmitter. Release both buttons after the indicator light changes from the slow to the rapid flash.
  5. Press and hold the just trained HomeLink® button and observe the indicator light. If the indicator light stays on constantly, programming is complete and your device should activate when the HomeLink® button is pressed and released.
    NOTE: To program the remaining two HomeLink® buttons, begin with "Programming" step two. Do not repeat step one.
    If the indicator light blinks rapidly for two seconds and then turns to a constant light, continue with steps 6-8 to complete the programming of a rolling code equipped device.
  6. At the garage door opener receiver (motor-head unit) in the garage, locate the "learn" or "smart" button. This can usually be found where the hanging antenna wire is attached to the motor-head unit.
  7. Firmly press and release the "learn" or "smart" button. (The name and color of the button may vary by manufacturer.)
    NOTE: There are 30 seconds in which to initiate step eight.
  8. Return to the vehicle and firmly press, hold for two seconds and release the programmed HomeLink® button. Repeat the "press/hold/release" sequence a second time, and, depending on the brand of the garage door opener (or other rolling code equipped device), repeat this sequence a third time to complete the programming. HomeLink® should now activate your rolling code equipped device.
From the HomeLink site: HomeLink; Home automation,Wireless control system, universal transceiver, RF control, Home security, smart home, vehicle to home, home automation, remote control lighting and home control
these instructions worked perfectly for me. Thank you very much for posting the complete information.
