Old Jan 6, 2024 | 08:28 AM
  #72 (permalink)
zip439's Avatar
zip439
Default Re: Help diagnose intermittent rough running
Originally Posted by svtmerc
So the charcoal canister vent valve seems to be the culprit. I dropped my car off to have them install the one I ordered and they informed me the one I gave them wasn't the same and sent me side by side pics, and they were correct. So I had a used canister and valve that i ordered, but the Y shaped hose nipple on it was broken off and rendered the canister useless. So i brought it to them so they could use the valve. they installed it and the car would barely start, and would nearly immediately shut off. They put the old one back on and it ran again.
I have looked and not been able to locate a correct valve. The one I ordered was for a 2004 SLK 320, and it does show a pic of the part that arrived, which is clearly different from the crossfire one which does not appear on rockauto nor anywhere I looked.
Has anyone found one anywhere?
There are two on ebay ( entire canister for a little over $100) Look at the part numbers on the correct parts which where on your car. The canister I believe should be 1704701259 the shut off valve will have it's own number. Numbers that start with 193 are specific to the Crossfire, NOT Mercedes, but the 170 number or 210 etc will be a Mercedes part. Some of those parts are now discontinued, but many are still avaliable directly from Mercedes or a supplier like Pelican, FCP euro etc.
