Old Mar 30, 2024 | 12:40 PM
pizzaguy
Default Re: there is fuel in the charcoal canister !
Originally Posted by Anthony C
Thank you for the response Zip.
I have a new cap on order.
As for the functionality of the three electrical components they do function as designed. Each one are activated by the ECU. The ECU would indicate a malfunction by setting a code. However there are none.
CAREFUL. Do not assume what I put in bold text unless you fully understand how the ECU determines there is a fault in this particular application.
One of the mistakes made during diagnostics is to not do diagnostics and instead, just trust codes without thinking things thru.
I admit that I do not fully understand the sequences involved in the EVAP system. If you fully understand it, fine. If not, be careful making conclusions, as once you turn your mind off to a possibility, you can waste a lot of time chasing your tail.
