Old May 2, 2024 | 12:37 PM
pizzaguy
Default Re: Electric Nightmare - ASAP ( alternator keeps blowing and a fuse)
Originally Posted by Mostafa Rostom
The yellow fuse below out. The car was parked in open ground during the winter and water got thru it. There is power when the ignition is turned ON but no clutching or engine running.
That fuse being blown won't stop the car from starting, but I'd not drive the car without that being fixed. As you have already been told, that is the Brake Controller Fuse.
If the car is powering up but not engaging the starter, which is what I get from your posts, try this:
Turn key to START, if starter wont engage, release key to "ON".
Wait 30-45 seconds - does the engine cooling fan warp up to high speed? If so, your Fan Module IS powered up but the ECU is not talking to it, probably cause the ECU is not powered up. This is usually a failure with the 'Engine Control Relay" output on the RCM. VERY common failure in our cars.
If the fan does not warp up to high speed, I'd have a lot more questions. Given the car has sat, and with known water intrusion, this one may be harder to fix than most - most of our failures are due to module or part failure. WIth water damage (and possible rodent damage), this may get complicated.
