Old Sep 26, 2024 | 12:16 AM
  #47 (permalink)
M60A3Driver
Default Re: blown turn signal bulb, or not?
Originally Posted by Coyote
Thanks for your response. In searching the forum, after a previous reply to my query, I found a solution that makes sense and will be implementing that in the
next day or so. I do appreciate you pointing me to a forum post pointing to the replacement relay. However, I think I found the solution from another response.
It seems to work, so I'll go with that now, but keep your info in the hip pocket in case I need to go beyond the current proposed solution.
I hope your solution works. Best of luck to you!
