Old Nov 1, 2024 | 06:51 PM
  #126 (permalink)
pizzaguy
Default Re: Convertible Top Sensors
Originally Posted by sfcoryea
I cannot lower my top manually because after I unlatch the front(windows stay up) it will not let me raise the bow enough to use the 10mm special tool to unlock the cover. Why will it not go up far enough? Will pulling the fuse release the bow so I can move it? Thank you, Scott Coryea
I am unsure if you are understanding the process. You must release any pressure on the system (and if the pump never ran, then there is no pressure.)
You then unlatch the rear bow by opening the trunk and using the hex key wrench. Pulling the fuse releases all pressure but again, if the pump did not run, pressure does not exist anyway.
Here is the process, I try to do thru it slowly so it is understandable:
