Old Nov 13, 2024 | 01:11 PM
bossman4's Avatar
bossman4
Default Re: 2024 Single DIN Wireless CarPlay solution ( Found )
Originally Posted by nedj10
I have been looking at the Power Accoustik unit for a week now after looking through all the single DIN options from aliexpress. My plan is run the backend USB A into a USB header somewhere inside the center console which I want to terminate in the storage compartment in the center console simlar to the way the USB-C ports are in a Tesla Model 3. My use case I want to be able drive Android Auto via USB so I can charge my phone and get AA functionality.
One question I have is have you messed with the Treble and Bass controls on the the Power Accoustik unit yet and if so does the audio sound good still? One of the complaints for the cheap Chinese units is they hae terrible DSP's and as result turning up the bass just muffles the input sound signal.
Just curious as to your results.
Thanks
Ned Williams
I have installed probably 5 different Ali Express units. Yes, they do vary in quality, but the main difference from an audio standpoint is the main chip and the amps. The particular unit that I installed has the newest "cpu" with a significant amount of cores. This greatly improves the performance and the ability to multitask. This makes the music experience more pleasant, since the unit can quickly handle multiple chores without bogging down. The amplifier chips have kind of plateaued over the last year and provide very good signal response and adjustability. The biggest change is the price to performance. There is a lot of competition and the performance that you thought would cost a lot of Ali Express money has gone down significantly.
There are still a few quirks with menu choices, but it is significantly better than three years ago. Apple Carplay and Android Auto really make things easier, but you always have native Android.
Sometimes the usb ports, front or back, do not provide a lot of power to charge. I have had cheaper units where the two back usb ports can only be used one at a time for files. The unit I have has a front end power usb that charge faster (no file transfer), but I am not sure of the back. My usb drives are in the glove compartment.
