Old Mar 18, 2025 | 05:00 PM
GraphiteGhost
Default Re: hesitation during acceleration
Originally Posted by zip439
The diagram shown by OP is for a SRT6. He stated in the first post and the pictures show an engine bay of a Limited. The hoses are NOT the same of the two models. The SRT6 from the factory has an additional hose routed to the bottom of the reservoir coolant tank that the Limited does not have. Also notice in the diagram the two small hoses coming and going to the intercooler.
That is not the correct diagram for a Limited.
Thanks for the clarification Zip! Now I know why I was so confused (we all know how diagrams are not that accurate in the SM anyway). I did see my duo-valve assembly, it just might be part of that bracket assembly (seems the duo-valve and the PS heat shield are on a bracket, without taking mine apart I have no idea if they overlap (two brackets together) or if the one bracket is the same as what he showed in his post.
xintersecty, is there a bracket on your duo-valve that mounts both on the wheel well area AND goes into the engine bay area to hold the front of the firewall/engine heat shield? That's about all I can see inside my bay where the duo-valve is located. Good luck!
