Old Mar 19, 2025 | 02:29 PM
xintersecty's Avatar
xintersecty
Default Re: hesitation during acceleration
Thanks for the clarification Zip! Now I know why I was so confused (we all know how diagrams are not that accurate in the SM anyway). I did see my duo-valve assembly, it just might be part of that bracket assembly (seems the duo-valve and the PS heat shield are on a bracket, without taking mine apart I have no idea if they overlap (two brackets together) or if the one bracket is the same as what he showed in his post.
xintersecty, is there a bracket on your duo-valve that mounts both on the wheel well area AND goes into the engine bay area to hold the front of the firewall/engine heat shield? That's about all I can see inside my bay where the duo-valve is located. Good luck!
I got my documentation from this link:
https://www.crossfireforum.org/forum...ollection.html
The parts catalog I used to extract the picture was labeled 2005 Crossfire Parts. I believe it covers both the limited and the SRT. So the picture I picked very could be for both. Again when you have senior members who know more about the car than the manufacture, you are going to get the details you need. And, that's a good thing,
Here is a picture of my duovalve.
Yes it's located above the passenger side wheel well. I am going to take another look in the car and chase down those lines. This is really weird. It could be some random addition to my car. The backet was mounted near the radiator closer to the fill tank. See the picture above when I removed it.
Currently, I am waiting on a needswings order (Thanks Rob) as my oil cap got busted and decided to replace the oil filler neck. I just ordered new oil for the oil change that will happen once everything is put back together.
