Old Apr 13, 2025 | 08:33 PM
pizzaguy
Default Re: Body Contril Module Question
Originally Posted by Bandit55
Pizzaguy,
I replaced the CLP and damaged wire/connectors recently due to water in the area where the CLP is located. It fixed the door locks problem but all of the other issues mentioned in my original post still exist.
So what am I missing?
Many Thanks!!
Brian
Let's take another look:
horn, - bad horn relay (it's on the RCM), fuse 6 on the RCM, bad clock spring, bad horn button
interior light, rear hatch light, - It's an 04, so these work together. Check Fuse 9 and 13, if they are good, the latch and door switches are wired to the CLP/SSM and it tells the BCM over the CAN bus to turn the lights on and off. I've not heard of the BCM failing in such a way these lights fail but I suppose it IS possible.
In short, check every fuse in the RCM and in the big fuse box on the driver's side, under the hood.
BAS, ABS, and rear spoiler random operation
POSSIBLY a bad RCM, but probably not - I'll vote for: weak battery or corroded battery posts/clamps or a resistive ground from block/chassis to battery negative post.
It would be RARE, but if the brake controller is not sending data about vehicle speed, or sending bad data, all these symptoms would be the result - but that is RARE in our cars, I suppose you could have a bad wheel speed sensor, it has happened. But again, kinda rare.
Try James' mod in this thread (it will cost you $20 and 1/2 hour of your time:
https://www.crossfireforum.org/forum...le-engine.html
DO NOT DO MY MOD, I no longer endorse it.
