Old Apr 25, 2025 | 10:15 AM
pizzaguy
Default Re: Fuse positions UK Cars
Originally Posted by Robskytoon
Hi does anyone have an uptodate list of fuses on a 2004 UK car, have some problem but difficult to resolve because workshop manual references fuses that are in particular places except they are not eg. Brake light fuse location 2 except in UK its 9, under bonnet ABS fuses 17 & 18 except not used in UK!
Would be a lot easier if I knew which fuse was which
This is a universal problem. First, the UK cars are not same as ours over here in the USA.
Second, even over here, they moved fuses around between SRT/Base/Limited with even more changes in 07-08 model years (06-07 to you).
If you have the card under the lid, it should be accurate, as there are many versions of the card. If the card is gone, well, welcome to the confusion......
