Old May 24, 2025 | 11:37 PM
M60A3Driver
Default Re: Recommendations selling ‘05 SRT6 Roadster
Originally Posted by Jhigby
I had found that video before too - definitely helpful! He shows that he’s able to snap that top down into the tonneau cover but I can’t. As far as lifting the back of the top up to close the tonneau it doesn’t sound like his engine is running when he’s demoing the process. I can do that part it fine if the engine is off but not when it’s on. Maybe I just need a helper on the other side of the roof - wouldn’t take much hydraulic pressure to make it difficult by myself?
I appreciate your help and linking the video!
Hi,
you can't do it manually with the car running. It keeps pressurizing the system and it will make it difficult to move the top in any direction.
Release the pressure when the engine is off as Mark said in the video. Then move the top to either open or closed. Repeat this process manually a few times.
Then try it using the button with the engine running.
Here's how to refill the hydraulic reservoir. Make sure it is at the max line before proceeding.
