Old May 28, 2025 | 12:02 PM
bobandsherry's Avatar
bobandsherry
Default Re: 2006 Limited OEM radio
Is there output from the head to the amp? The failure of the battery (or what caused that failure) could have taken out the AM/FM head (what you call the 'radio") or it could have taken out the amp.
Either your head unit or amp is bad, you are assuming (is seems) that the fault is in the head (radio), this is not always the case.
I suspect the amp is where the issue is. Have you verified the fuse to the amp? (Fuse 23 in the underhood box, in most model/year variations, check the card in the fuse box lid to be sure.)
many thanks for the quick reply. I will check the fuse and hopefully that will fix it. Thanks again.
is the amp a separate component from the radio or is it located within the radio or the head?
