2006 Limited OEM radio
Old May 28, 2025 | 09:15 AM
bobandsherry's Avatar
Default 2006 Limited OEM radio
Radio turns on and the display works. There is no audio at all not even a buzz. Had to replace the battery in the car and radio hasn’t worked since. It had been finicky for a while and will work sporadically before the battery replacement. Any suggestions. Thanks.
Old May 28, 2025 | 11:41 AM
Default Re: 2006 Limited OEM radio
Is there output from the head to the amp? The failure of the battery (or what caused that failure) could have taken out the AM/FM head (what you call the 'radio") or it could have taken out the amp.
Either your head unit or amp is bad, you are assuming (is seems) that the fault is in the head (radio), this is not always the case.
I suspect the amp is where the issue is. Have you verified the fuse to the amp? (Fuse 23 in the underhood box, in most model/year variations, check the card in the fuse box lid to be sure.)
Old May 28, 2025 | 12:02 PM
many thanks for the quick reply. I will check the fuse and hopefully that will fix it. Thanks again.
is the amp a separate component from the radio or is it located within the radio or the head?
Old May 28, 2025 | 12:14 PM
The AMP is separate and I believe it is located under the passenger floor in front of the passenger seat
Old May 28, 2025 | 12:42 PM
Gary is right, it's under the feet of your passenger. Base/SE cars do not have an amp. Limited/SRTs have the amp.
Old May 28, 2025 | 11:58 PM
Am curious, there is a fuse in the back of the radio. When blown, what exactly doesn't work on the radio? Just a thought. If you want to check the fuse there, you have to have the radio keys placed into the lower left and right slots (and push in being careful to have the right key in the right slot and the left key in the left slot).I can not remember if this fuse has ever been mentioned before as to if when blown, the display lights up or not. Also, a few posts before has a reset for the radio when it acts up but again, I don't remember what was done when the reset is done correctly (buttons or some sequence). Good luck!
David Whitney
Mar 4, 2025 03:13 AM
kstewart
Nov 4, 2020 09:16 AM
frankjones48
Apr 17, 2015 08:23 AM
cornetnut
Jun 26, 2014 04:52 PM
Christopher12284
Jul 29, 2008 09:24 PM
