Thread: Won't start
Old Aug 5, 2025 | 06:30 PM
pizzaguy
Default Re: Won't start
Originally Posted by Katmando
Ok, so he pulled a fuse and now it won't go back in due to the connector inside the fuse box has fallen. How do you remove the fuse box? Tried to find a video on YouTube but couldn't find it
Are you talking about teh underhood fuse box, driver's side?
IF so, you simply release the catches and lift the "fuse carrier" out of the box so you can get under it. I use a flat blade at the front to free the front tabs and lift the front up, then the entire carrier will come out.
A prying action is needed to kind of push the box wall forward so the tabs on the fuse carrier are free of the box.
