Climate control manual or semi-automatic???
Old Nov 10, 2013 | 01:29 PM
Reichsrundfunk's Avatar
Default Climate control manual or semi-automatic???
Hi All,
Is the climate control system on the 2004 Crossfire a semi-automatic system or a fully manual system? Other than manual operation of the blower motor and air output settings, is setting the temperature thumbwheels controlling any kind of automatic temperature regulating system or does it only regulate the monovalve or air mixture manually, with no input from thermostats etc?
I recall reading in the manual on air conditioning mode that it made no difference turning the temperature wheels to colder that the system would cool down at the same speed regardless. But does this hold true for the heat?
My Mercedes is equipped with a full-automatic system in that you set the temperature and it maintains that temperature regardless of interior or exterior temperature, and regulates fan speeds too. As the interior reaches the set temperature range, the air will become cooler and warmer depending on variation from the set temp. Will the system in the Crossfire do this also?
-George-
Old Nov 10, 2013 | 05:45 PM
Default Re: Climate control manual or semi-automatic???
Originally Posted by Reichsrundfunk
Hi All,
-George-
It is a manual system. you have to dial heat/cool, and you have to set fan speed. If you had an automatic system, you would have a temperature readout that you set, and the system would maintain that set temperature.
Old Nov 11, 2013 | 03:25 PM
Egodriver71's Avatar
Seems like a fancy dual zone version of the old manual systems.
The dials to not control a temperature, they are just how cold to hot you want the outlet air to be through the blend doors.
Old Nov 11, 2013 | 05:14 PM
We are better off with the manual system.
Diameler automatic temperature systems suck.
syfi
Mar 28, 2026 04:14 PM
Osusannah
Feb 12, 2024 01:49 PM
johnnycross413
Mar 4, 2016 04:49 AM
2005 Ragtop
Oct 3, 2015 03:01 PM
Billy22Bob
Sep 26, 2015 10:16 PM
