Axle stand points
Old Sep 21, 2014 | 02:04 PM
Oconnom's Avatar
Default Axle stand points
I've searched forum and handbook, cannot find anything. Where are the recommended axle stand positions on a Crossfire ?
Mick
Old Sep 21, 2014 | 05:18 PM
Wes__Hutchinson's Avatar
Default Re: Axle stand points
I would use the jacking pads.
Old Sep 21, 2014 | 06:21 PM
Oconnom's Avatar
So where do you place the jack to raise the car to allow you to position the axle stands under the jack lads ?
Mick
Old Sep 22, 2014 | 07:19 AM
You start by jacking up the rear by placing the floor jack under the differential, this will allow you to raise high enough to get 2 fully collapsed jack stands under the 2 rear jack pads.
Then move the jack to the front where you will find a cross member just behind the engine.
This will allow you to raise the front enough for the other 2 jack stands under the front 2 jack points.
Old Sep 22, 2014 | 07:56 AM
Oconnom's Avatar
Thanks, just what I wanted to know. Didn't want to jack it up in the wrong place !
Mick
Old Sep 23, 2014 | 02:17 PM
crymar's Avatar
I place a 4 ft. 2X4 between the jacking points on driver's side of the car. I then position my trolley jack under the middle of the 2X4 and jack up that side of the car. I put small wooden plugs in the jacking points to prevent marring them with the jack stands, and then set the jack stands under the jacking points and lower the car. I then do the same on the passenger side.
Old Sep 23, 2014 | 03:19 PM
Oconnom's Avatar
Crymar,
Thanks, that's a good idea, especially if you want to lift one side rather than the front or rear.
Mick
Old Sep 23, 2014 | 03:24 PM
crymar's Avatar
The jacking points are the four little black plastic pads located behind the front wheels and in front of the rear wheels under the door/fender sills. They accept the jack that came with the car. Your owner's manual shows you.
Old Sep 23, 2014 | 03:34 PM
Oconnom's Avatar
Crymar,
Got that , even made some small wooden blocks that fit in the plastic hack points to protect them when I jack up one corner with my hydraulic jack. I probably didn't explain myself in my original post, I just wanted to know where to jack the car, but not using the jack points. I now have the answer.
Planning on doing a brake fluid transfusion in the next few days.
Mick
Old Sep 23, 2014 | 03:48 PM
crymar's Avatar
Your post was clear. The confusion resulted from me responding directly from the e-mail alert which only noted your original post that started the thread. So, my post was just added to the que. When I went to the forum I saw my mistake. Good luck with your Crossfire.
Old Sep 23, 2014 | 08:40 PM
deltacrossfirebob's Avatar
Oconnom
When i did my brake job, i replaced the bleeder zerks with "Speed Bleeders".
They are great.
Do all four at one time.
Clear tube pushes on to each so you can do a clean drain.
Have fun
Old Oct 1, 2014 | 10:41 AM
boostmonkey's Avatar
If you jack up the rear first, there may not be enough clearance to get your jack underneath the nocse. I recommend doing the front first if using this method.
Old Oct 1, 2014 | 11:38 AM
grip grip's Avatar
But if you jack up the front first, there may not be enough clearance to get your jack underneath the rear. Just kidding.
Old Oct 1, 2014 | 01:16 PM
Actually, it's the other way around for me. I can't get the jack under the front, until I get the rear jacked up and on stands.
NOTE: I do not go in from the front after the rear is up, I go in from the side about middle way. The jack is at an angle on the cross member, but it works.
Old Oct 2, 2014 | 11:09 AM
That is the difference. I was referring to coming in straight from the front.
rmcdaniel12
Nov 4, 2015 04:08 PM
Mackel
Oct 16, 2015 09:03 AM
jimf
Oct 10, 2015 10:22 AM
ritous1
Sep 26, 2015 01:27 PM
eatmycrackers
Sep 23, 2015 09:08 AM
