Water In Needswings Intake
Re: Water In Needswings Intake
Yep I use them too just to be safe and have never had a problem.
I've never had a problem even in tropical storms. For that matter, for a while I was spraying water/meth. First before the supercharger and later in the Y pipe. As long as you keep the filters clean and oiled you shouldn't have a problem. Is your car NA or SRT? The supercharger loves the cooling effects of water .... as long as it's just a mist.
Les
Les
Ive nvr had a problem sucking running in through my NW DCAI either (srt6). I just dont see how it would be possible as it has to travel up a long inclined distance to get to the TB in the back of the motor and the only way I could see it happening if you had the throttle wide open in a down pour, but im not sure if that would generate enough vacuum to suck the water all the way up.
