Some uses for the old oil change O rings
Old Dec 5, 2017 | 10:40 AM
Default Some uses for the old oil change O rings
Put some bling on the heater control valves
( cleaned with lacquer thinner, then 2 coats of Kilz, then ceramic caliper paint ) :
Cover up those rusty threads on the water pump pulley :
AND, I'm pretty sure the really big one will fit the throttle body, but haven't personally verified that.
Old Dec 5, 2017 | 10:56 AM
Kingdav1954's Avatar
Default Re: Some uses for the old oil change O rings
LOL !! You've got waaaay to much free time, I think you need another project to go with all the others 😏
Old Dec 5, 2017 | 11:02 AM
I KNOW !!! This being retired stuff is driving me CRAZY
Old Dec 5, 2017 | 11:22 AM
I'm two years away from retirement and I'm trying to find every excuse I can to put it off, but the wife is breaking my coconuts about it and wants me to take early retirement. I keep asking her, and do what? Travel? I already do that for a living now!!
Old Dec 5, 2017 | 02:56 PM
The O-ring for the throttle body should be Viton, the regular O-ring can not take the temperature for extended periods of time and hardens up.
Old Dec 5, 2017 | 03:00 PM
Agreed, but can you explain why the O ring is almost completely deteriorated each time someone removes a TB ?
Old Dec 5, 2017 | 03:15 PM
​​​​ heat degradation ?? The only thing that travels through it but does not touch it is air.
Old Dec 5, 2017 | 03:19 PM
Steve Jr's Avatar
I figured ,it was raining at George's house today or he had been banished to the garage,, for some reason...lol.
Old Dec 5, 2017 | 03:21 PM
Yea, but since the manifold is bolted to the engine that averages 190 F, there is bound to be some heat buildup.
What I can't figure is that this same O ring is in the oil filter assembly that also averages 190 F, so why wouldn't it deteriorate there too ?
Old Dec 5, 2017 | 05:02 PM
daveesrt6's Avatar
[QUOTE=ala_xfire;898286]Put some bling on the heater control valves
OK thats it , i have to do this , they do look very nice painted !
i need a new project anyway , i was getting bored with taking endless pics of my car
Old Dec 5, 2017 | 05:05 PM
The oil filter O-ring is changed once in a while, the throttle body O-ring hardly ever if at all. The filter O-ring is also kept moist, maybe that helps.
Remember the O-ring in the dip stick tube that was brittle a week or so ago?
Old Dec 5, 2017 | 05:50 PM
OK, you convinced me. Viton it will be.
Old Dec 5, 2017 | 06:05 PM
waldig's Avatar
Talking Re: Some uses for the old oil change O rings
Yeah retirement is a bit ch as you never get a day off and there is no sick leave or freedom from the knowledge that your ON YOUR OWN TIME and your near the end so DONT WASTE IT! Been running from project to project with no let up, work was a time to think about projects and you could think of the free time and what you could do on your time OFF..............................Enjoy, WOODY
Old Dec 5, 2017 | 06:22 PM
Viton is a trade name, the material is actually fluorocarbon.
Max endorsed this some years ago.
Old Dec 5, 2017 | 07:05 PM
LOL! it's the" near the end" part that I'm trying to avoid ¥
Old Dec 6, 2017 | 09:38 AM
ewaynec's Avatar
Please, I have a project. I need to replace my valve cover gaskets. I don't want to do it and I will not take it to a garage. If any of you retired gentlemen need a project you can have mine, I don't want it.
Old Dec 6, 2017 | 09:59 AM
I'll take it, but you are a bit far away
Old Dec 6, 2017 | 01:41 PM
JEFASOLD's Avatar
W.C. Fields, a notoriously non religious man, known for his hard drinking, was found reading a bible on his deathbed. An astonished friend asked him what he was doing, to which Fields replied "Looking for a loophole". I have found that retirement brings a whole new batch of "things" to do, to the point that you wonder how you got anything done before retirement.
Old Dec 6, 2017 | 02:43 PM
😂🤣 That's hilarious!! From now on when someone asks me, how are you? I'm going to answer; unsuccessful at finding the loophole !!
