1.5 amp battery drain!
Old Jun 30, 2018 | 02:15 PM
Abaton6's Avatar
Default 1.5 amp battery drain!
05, 68K miles.Read some threads on this, but no solution yet. I put an ammeter between the negative cable and post. I'm showing a 1.6 amp drain. The car runs fine. I'm getting 14.3v to the battery while running. I pulled every fuse under the hood, still draining. My light switch is in the straight up position. Pulled the trunk bulb out. No lights on in car/ glove-box. Thank you in advance for any suggestions. Still love this car!!!
Old Jun 30, 2018 | 04:10 PM
Default Re: 1.5 amp battery drain!
If you pulled every fuse under the hood did you pull all the fuses in the dash?
I cannot think what it could be but I would try this as well in desperation.
How about some leak at the alternator, unplug this as well.
Old Jun 30, 2018 | 06:00 PM
WHy did you give up so fast? You are almost there.
There are three fuses in the box next to the battery.
1) 200 amp - feeds the whole car except the starter/alternator cable, and items 2 and 3.
2) 50 amp - Brake Controller
3) 50 amp - Fan Controller
If you yank all three and still have the current, it's in the cable going to the starter/alternator. Yank the big lead off the alternator and if it goes away, get a new alternator (diode(s) leaking).
Otherwise, it's the starter solenoid (not likely).
If it goes away with the 200 amp fuse and you have every other fuse out, then you are where I ended up with Marie's car in north Georgia: there is a flow thru some unfused lead that I did not have time to chase. But I did find the actual wire, there is a junction of high current red leads under the underhood fuse panel. If you have this and find the one that is causing it, leave it disconnected and start the car up and see what is not working, go from there.
Old Jun 30, 2018 | 07:50 PM
Padgett's Avatar
!.63A is a lot- usually a light bulb and will kill a battery in a day.
That said have you checked the body fuse box in the dash (have to open the driver's door to see) and the circuits in the Relay Control Module ?
Old Jun 30, 2018 | 10:36 PM
Abaton6's Avatar
Thanks all. I will go through these suggestions tomorrow, then update.
zalsaigh
37
Jul 18, 2022 11:17 PM
2005 Ragtop
May 11, 2014 12:13 PM
joe lonardo
Jul 1, 2010 07:22 AM
ckovach
Jan 22, 2010 07:31 AM
blackcrossfire07
Mar 18, 2009 10:50 AM
