battery drain
Old Jun 30, 2010 | 08:32 AM
joe lonardo's Avatar
Question battery drain
Purchased a 2007 roadster in May, went away for 2 weeks, when i came home car was stone dead. Took awhile to jump it and finally started. two days later dead again. Replaced battery and checked for battery drain with car off, my reading was .0170 milliamps. I was told it should not be more than .0050. Anyone have similar problem or some advice?
Absolutely love the car but I am worried if this is an ongoing thing.
Many thanks
Joe Lonardo
Old Jun 30, 2010 | 09:21 AM
Default Re: battery drain
Originally Posted by joe lonardo
.0170 milliamps.
I think you mean .170 amp which is 170 milliamps. And yes, anything over maybe 50 milliamps (.050 amp) is suspect.
Can't say I've heard anyone else having a problem with battery drain... but you can insert a meter and start pulling fuses until you find it. Beware I've seen alternators get leaky (actually the DIODES in the Alternator are usually the problem) so try pulling the cables off the alternator to check that.
A drain of even .070 amp (70 milliamps) may not be all that bad. Modern cars with all their electronics often experience drains of 25 to 70 milliamps, we run into this all the time. (I work in a Motorola shop and we maintain the equipment in police cars.)
Old Jun 30, 2010 | 09:35 AM
Thanks very much Pizza guy.
I actually did pull the fuses and found that it dropped to .070 when i took out the 10 amp fuses for the dome lights, horn, and door lock. How long should I wait to make sure that all systems "go to sleep" before testing again? I tested by using multi meter with negative cable off and and putting meter in between cable and battery post
Joe Lonardo
Old Jun 30, 2010 | 11:00 AM
Learnin's Avatar
Joe Lonardo
Joe,
You might have already done this but you can type in, "battery drain" in the search engine and read some threads there on this subject. Seems like some people attributed their battery problems to trunk light....
Old Jun 30, 2010 | 10:43 PM
Joe Lonardo
I believe most systems are in their "powered down" state after just a few seconds. That's what I have observed at work, anyway, with most cars.
I found that on my Roadster, the trunk light stays on unless the trunk lid is FULLY closed.
Old Jul 1, 2010 | 07:22 AM
kingkub57's Avatar
Our cars stay on longer than that, because you can still use the radio, and the fan rest button function for about 20 minutes or so before the system shuts down completely, its called retained accessory power, as long as you do not open a door, and with the key off.
syfi
Mar 28, 2026 04:14 PM
blackpepper
Oct 4, 2017 06:09 AM
o55ie18
Oct 5, 2015 05:50 PM
rmcdaniel12
Sep 22, 2015 01:20 PM
Valk
Sep 17, 2015 11:43 AM
