Transmission Leaking
Old Apr 29, 2019 | 09:02 PM
Penwa's Avatar
Question Transmission Leaking
Hello, I got my oil changed on my 2004 Crossfire Limited Coupe and received a list of issues that needed to be repaired/replaced. One of the items on the list is that the transmission is leaking. I'm skeptical because I keep my car in the garage, and there isn't any pink fluid on the floor, plus no check engine light, and it's shifting smooth. I've had the car for a year now. It had 45K original miles on it when I bought it, and it currently has 58K miles. Is it possible that the transmission fluid just needed topping off? I tried to check the fluid level and I couldn't get the cap off the dipstick...then I read about the break the seal to open, and you have to replace the cap, good Lord. Now I am wondering whether the difficulty in checking the transmission fluid yourself makes it an easy target for an unnecessary repair. Any advice?
Old Apr 30, 2019 | 02:08 AM
Speedy4x4's Avatar
Default Re: Transmission Leaking
Most transmissions on the road leak, but the questions is, how much, most just have some drips on the case and never would make it to the ground.
I would put a mat underneath the car, and wouldn't worry about it till you see some drips on the mat.
Old Apr 30, 2019 | 09:48 AM
There is a way to take off the cap without ruining it, I have forgotten how, it needs to lock in place as you do not want it to blow off.
There is a connector that has OEM O-rings in it, the part and O-rings costs about $10. Also one leak has the oil wicking up a cable and into the car by the passengers feet, that can get expensive to fix. Sometimes a leak gets blown back along the underside of the car and it can take a while to drip.
Sometimes the list of problems is actually a figment of the mechanics imagination, he gets a cut of the prices charged in most dealerships. Independents make their money on fixing your car, not for being good guys.
Old May 1, 2019 | 09:58 AM
Rajunz's Avatar
More than likely it's the seal where the wiring harness goes in to the transmission.
Old May 5, 2019 | 12:15 AM
lovecross's Avatar
Post Re: Transmission Leaking
A minor tranny leak @ the aforementioned connector is common due to o-ring failure, our's did drip a little. I think that part may have been upgraded/improved from original. Checking fluid level is a bit tricky, you need the correct dipstick or one that will fit down to the bottom of the pan. Then you need to check it for the correct level which is temperature sensitive. None of this is terribly difficult nor expensive for competent D.I.Yourselfer. Like many cars, transmission dipsticks are not provided & not kept in the transmission.
You may want to find a reputable German car repair shop & tell them what you've learned. If they are experienced (at all) w/Mercedes, they should be familiar with this. A fluid change, due to age, might be wise.
Pierantonio
Jan 16, 2017 06:32 PM
scsponger31
Jan 23, 2011 10:18 PM
Mabs
Apr 25, 2009 07:50 PM
dcspride
Apr 1, 2008 05:53 PM
Nightrider
Apr 15, 2007 11:11 PM
