why 8 and not 4 liters of oil?
Old Jun 29, 2019 | 08:49 AM
phil alvirez's Avatar
Default why 8 and not 4 liters of oil?
why crossfire capacity is 8 liters and most cars use about half? does needing about twice means something is better? and if so, what?
thanks
Old Jun 29, 2019 | 11:47 AM
Default Re: why 8 and not 4 liters of oil?
First of all, welcome to the family.
Now, "Windsor" where? If you provide more information on where you live, local owners will reach out to you and include you in local events.
As to oil quantity, there are a few reasons to increase oil quantity:
1) Additional oil provides a 'heat sink buffer', that is, the extra quantity can help with temperature swings that occur during short-term harder driving, keeping oil temp more stable
2) Additional oil provides more dilution, that is, you can go longer between changes because contamination is more diluted (so the marketing department can claim more miles per change)
3) The engine can run on six and 1/2 quarts, so IF the engine were to use or loose any oil, you have no real urgency to add oil. (Check your owner's manual carefully, it specifies 8 1/2 and that you can go 2 quarts low; of course, I only do 8 quart changes because the last 1/2 quart can set off the hi oil alarm)
Old Jun 29, 2019 | 11:59 AM
4) stealerships can stick it to you more for 8 1/2 quarts as opposed to 5 quarts.
Old Jun 29, 2019 | 12:41 PM
See my point about marketing. The dealers and Chrysler's marketing department are incestuously connected.
Old Jul 5, 2019 | 05:23 AM
thank you for your great advice.
Thirteendog
Aug 19, 2008 04:00 PM
Jan 23, 2008 10:13 AM
andrew
Other Cars Etc
Jun 28, 2007 11:12 PM
andrew
Other Cars Etc
19
Mar 27, 2007 12:58 AM
