Gravity bleed brake/clutch system
Old Aug 29, 2019 | 11:52 AM
dcskmail's Avatar
Default Gravity bleed brake/clutch system
Has anyone did a Gravity bleed of the brake/clutch system ? Are there any problems doing it with the ABS
thanks for any help it's very much appreciated
Dennis
Old Aug 29, 2019 | 01:24 PM
Tbirdtony's Avatar
Default Re: Gravity bleed brake/clutch system
dcskmail, My sister and her husband own a 2010 Ford Fusion. The master cylinder failed and my sister's husband replaced it. He tried bleeding the brake system at least 5 times using the old "pump, pump, hold" method and could never get all of the air out of the anti-lock braking system. He finally had the car flat bedded to the local Ford dealer and they checked out the brake system (no problems found except for air in the system) and pressure bled the system and the car has been fine ever since. I would recommend that if you work on the Crossfire braking system or just want to flush out the brake system and install new brake fluid that you have a mechanic with a pressure bleeder do the work. You don't want to be driving the Crossfire and the brake pedal go to the floor.
Old Aug 29, 2019 | 02:04 PM
https://www.summitracing.com/parts/m...waAgMAEALw_wcB
reb
Jul 10, 2019 03:12 PM
JeffS
Apr 21, 2014 10:10 AM
meh03
22
Mar 13, 2014 11:12 AM
e2360
Apr 27, 2010 02:17 PM
pizzaguy
Jul 22, 2009 08:20 AM
