Rough starting after replacing camshaft position sensor
Old Oct 20, 2019 | 03:37 PM
MichaelG's Avatar
Default Rough starting after replacing camshaft position sensor
I replaced camshaft position sensor today and everything worked normal after installation. Went out to go to store after a hour or so. When trying to start, the engine motor boated (tried to start, but never fully got running). Turned key to off, waited a minute and car started just fine. Next time I tried to start it same scenario. Any ideas as to what is causing this?
Old Oct 20, 2019 | 04:31 PM
Default Re: Rough starting after replacing camshaft position sensor
Did you install a Bosch CPS? A lot of the other brands do not work properly.
Old Oct 20, 2019 | 04:55 PM
MichaelG's Avatar
Yes, it’s Bosch.
Old Oct 20, 2019 | 04:56 PM
MichaelG's Avatar
Can the new CPS cause this kind of issue? I guess I could reinstall the old one to see if issue resolves itself.
Old Oct 20, 2019 | 05:25 PM
MichaelG's Avatar
Re-installed original CPS. Problem resolved. Looks like I got a defective CPS. Time to return it for a refund or replacement.
white04XF
22
Dec 28, 2019 11:46 AM
phil alvirez
27
Oct 13, 2019 07:09 AM
xfireon20z
Jul 20, 2015 04:35 PM
vinnys
Jun 12, 2014 11:29 PM
maxime75us
Mar 28, 2013 02:42 PM
