Freakin’ CPS locking connector
This ain’t that hard as I changed out the Camshaft Position Sensor with ease.
im having trouble unbuttoning the Crankcase Position Sensor’s connector MAINLY because I don’t have a good view of its makeup AND I have big hands. My wife has small hands but refuses to help.
Is it the same type of cover as the camshaft connector ?
I have enclosed picture of my Camshaft Sensor Connector.
willing to trade my wife with your wife or girlfriend IF they don’t mind grease, or cuts, or soiled shirts
WRONG. You are doing this WRONG!
FORGET the damn connector. Do this:
1) Grab the ratchet, with extension and socket.
2) Use the above to start taking the screw out.
3) As the bolt loosens, grasp the ratchet with one hand, and the connector (with CPS attached) with the other.
4) As the bolt comes loose, gently pull the CPS out, holding the ratchet so as so hold the bolt in the hole of the CPS.
5) As the entire assembly clears the heat shield and comes into view, gently set the rachet down. Then, grab teh bolt and set it down.
6) Disconnect connector from CPS.
THIS way, you don't struggle with that damn connector and you don't loose the screw!
cajuncrossfire
Aug 28, 2008 06:27 AM
sonoronos
Jun 3, 2008 07:50 PM
