View Poll Results: Is loss of power common in srt6 models?
Was loss of power from intercooler
0%
Was loss of power from transmission
0%
Did you have to replace ECU and get a tune
0%
Multiple Choice Poll. Voters: 0. You may not vote on this poll
Loss of Power after few minutes
Old Aug 13, 2020 | 02:12 AM
Twilightprice's Avatar
Default Loss of Power after few minutes
Hi my name is twilight
Got a srt6 that looses power after a few mins of driving, then will gain power back somewhere along the road to my destination Or not. I’ll mash on the gas off a red Light, pedal to the floor and nothing but lag. Sometimes I mash the gas and instead of the feeling of throttle opening up and gaining speed quickly, it’ll have a hesitant feel but make noises like it hauling tail. RPMs max out in this situation but for some reason when I slap the shifter as if it was in manual mode gears shift but still lag. At times I can hit the gas from zero...fly to 59 hit 60 and boom lag! Sometime straight to 100 no problems. No check engine light so sensors are eliminated. I’ve heard things like intercooler, intercooler pump- not seeing overheating. Took it to high performance shop today, mechanic said it can be the supercharger clutch no engaging! Something about warm gear within or some magnetic something????!!!!Anyone with similar symptoms??? I need help!! I got smoked by a 93” civic last night...
Old Aug 13, 2020 | 03:37 AM
Sussudio's Avatar
Default Re: Loss of Power after few minutes
Make sure you’re gapped correctly between the clutch and the pulley. If it’s not, there’s your problem.
Also if it isn’t the upgraded Bosch ICP ending in part numbers 010 then your pump is going to fail if it isn’t/hasn’t already.
Old Aug 13, 2020 | 04:01 AM
Sussudio's Avatar
The correct gap is .35 -.45mm by the way.
Old Aug 13, 2020 | 09:19 AM
If you had used the SEARCH feature you would have found that the IC pump was generally the problem. Get the Bosch pump with the part number that ends in 010, if you have the pump that ends on 002 the rotor inside disintegrates.
There is a PDF on how to replace the pump and you can search for that easily.
Old Aug 13, 2020 | 09:30 AM
Thanks
ok where would the part number be located on the pump
Old Aug 13, 2020 | 11:57 AM
Thanks
As shown below. The new pump #0392022010 is shown, the old pump which often failed is #0392022002.
Do NOT buy from a Mercedes dealer or use the Mercedes part number as it will cost much more.
Old Aug 18, 2020 | 11:46 PM
I do have the 010. So that’s not the issue. The dealer I purchased it from (non Chrysler) said upon reading the codes from computer it came up that boost and egr codes showed. However he claims the RCM control all of that & was 90% sure on RCM. What are your thoughts from that? Also tried to charge me $598. Didn’t get it though. I serious feeling like it may be the supercharger clutch...lmk crossfire experts plz
Old Aug 26, 2020 | 11:02 PM
Sussudio's Avatar
Did you ever get your problem figured out?
Old Oct 29, 2020 | 11:41 PM
JB007Rules's Avatar
Following. I have this EXACT same issue currently as posted here: https://www.crossfireforum.org/forum...l-my-srt6.html
Thanks!
devilduck
Nov 23, 2017 11:23 PM
suhail.khawaja1
Oct 30, 2017 08:11 PM
kingtj
May 8, 2017 09:14 PM
Pjj51
Aug 23, 2016 09:54 AM
oyster_gold
Nov 17, 2011 11:07 AM
