Gear selected not plausible Gear 1 & Gear 3
Old Oct 19, 2020 | 05:00 PM
VintageBikesUSA's Avatar
Default Gear selected not plausible Gear 1 & Gear 3
Help, I went to look at a NA auto Roadster today and they tell me once the car gets warm the trans acts funny , will drive later but ever heard of these?? "Gear selected not plausible Gear 1 and then Gear 3. I did not check the fluid because my dipstick for trans was not here yet. 1st code ended in 64 and the 2nd was 60. I did not write them down but I dont see anything close to that on the DTC list. Never heard of this before, do you think its just low or something major. I lowballed him early this morning hoping they had some bills needing paid.
It sounds like the car is going into "limp" mode after the trans gets warm . I will drive it on Tuesday and was hoping someone would chime in saying its Low. I really thought I would remember the codes since there was only the two but that did not work out well. I have my chart and the dipstick so I will check the trans fluid cold and hot. I think it also has RCM issues that they are saying is a bad alternator. We shall see. It is a Yellow Roadster , Auto . paints bad, top is ripped and 2 rims are chrome OEM, the other two are not.
Old Oct 19, 2020 | 07:21 PM
Default Re: Gear selected not plausible Gear 1 & Gear 3
Originally Posted by VintageBikesUSA
1st code ended in 64 and the 2nd was 60. I did not write them down.
Ya gotta be kidding us.
Old Oct 22, 2020 | 11:20 AM
zip439's Avatar
Just the other day I was checking fluid levels on my Limited. I found that the low temperature range is not reliable. The upper marking when the car transmission was warmed to 80C was right at the mark for that temperature. I used a scan tool to get the temp of the transmission fluid and also found large temperature differences depending if the car was in Park or in 2 or third gear. I was working by myself so while using the dipstick I had the car in Park. My car has no transmission problems. I made the measurements to satisfy my curiosity in the event I may need the info sometime later down the road.
Old Oct 22, 2020 | 06:23 PM
Try pointing a laser temp reader at the tranny oil pan and see what you get.
Old Oct 24, 2020 | 02:35 AM
reb's Avatar
reb
Run,don't walk away from that money pit.
May 23, 2016 05:45 PM
canman80
Nov 14, 2009 12:22 PM
amx1397
Nov 17, 2008 06:05 PM
xfireblur
Feb 28, 2008 03:52 PM
makeithappen
Jan 11, 2008 08:11 AM
