Car does not start
Old Nov 22, 2020 | 08:18 PM
Agarcha's Avatar
Default Car does not start
Hello
Let me explain the situation. I recently bought a 04 Chrysler crossfire. First of it had no keys, so I could not start it at all. After looking around in the engine I had discovered that there was no ECU as well. So I proceeded to order on ebay and buy Key, Ignition, ECU and SKREEM online. It all came in one set. Once receiving all of these items I had changed the ignition, added the ECU and Changed the SKREEM. So I had attempted to turn on the car but nothing. The one I did notice is that the locking system was working. So the door, trunk, and everything else locked, The next day I went outside to check and then it stopped working. I got locked out of the car. I managed to get myself in with the help of a friend but the locking system stopped working in its entirety. I opened the trunk and thought that maybe it was the battery that was not dead. So I bought a new one and nothing. Then I turned the key and I heard the starter but then it stopped. So later I changed the spark plugs. After that I turned on the ignition and it ran for the first time and then died , second time turned the key started and then died. Third time nothing, just click, no starter nothing. This is where I currently stuck at. I have no idea where to go on from here. I’ve already solder the RCM, but nothing.im thinking that its either The three things which is either the key, ECU or Skreem.
Old Nov 22, 2020 | 08:57 PM
Default Re: Car does not start
Originally Posted by Agarcha
Hello
I turned on the ignition and it ran for the first time and then died , second time turned the car started and then died. Third time nothing, just click, no starter nothing.
im thinking that its either the key, ECU or Skreem.
If the description you provided above in bold has occurred it is the SKREEM
Common SKREEM failure scenario
Two places that can replace or refurbish your SKREEM
https://www.needswings.com/crossfire-skreem-repair
S.O.S. Diagnostics
Old Nov 23, 2020 | 09:16 AM
You will need to send the key(s), SKREEM and ECU in. I suspect they will need the VIN of the car those parts came from, but maybe not.
Old Nov 23, 2020 | 09:43 AM
Just to be sure it is probably the screem, disconnect the negative battery cable for a few minutes and then reconnect and try starting again. If you get the same two tries then nothing it is probably the screem. If not, I would replace the RCM and see what happens.
Auto
32
Feb 13, 2022 11:24 AM
flapper6557
Jan 22, 2020 01:47 PM
blankenshipl09
May 12, 2019 10:24 PM
Ajbarbier
23
Dec 12, 2018 12:15 AM
SRT6STORM
Sep 1, 2011 10:54 PM
