Disassembly of center console arm rest lid
Old May 11, 2021 | 08:36 PM
WHski's Avatar
Default Disassembly of center console arm rest lid
So the latch on my center console lid has some issues, some pieces have broken about the latching mechanism. Anyone have directions on disassembly of the lid to allow you to get to the latching mechanism? I've gotten the center silver trim off, but need further disassembly guidance.
Thanks to All on this Forum!
Old May 12, 2021 | 12:42 AM
UrbanE's Avatar
Default Re: Disassembly of center console arm rest lid
Download the service manual
it can be found online on this forum.
looking for the answer within the manual will be the best thing you can do.
Old May 12, 2021 | 06:07 PM
WHski's Avatar
Thanks, yes I checked the manual. The latching mechanism for the rear center console lid is what I need access too, and that is not discussed or outlined in the manual. I'll need help from someone who has taken apart the lid for the repairs I'm looking to make.
Old May 12, 2021 | 06:45 PM
I have the lid in my hand and from what I see there are the screws holding the silver panel on. Does the part split apart after this panel is removed? The base is made from two parts, can they be pried apart or are the glued together?
These parts have to be apart to assemble the latch.
It may be that you will have to buy the correct colour base on eBay and fix your silver trim to it if the silver colour is wrong or not as good as yours is.
Frankly I think buying a replacement part is the best idea as that spring hinge would be a nightmare to reassemble.
Old May 13, 2021 | 10:36 AM
WHski's Avatar
Thumbs up Re: Disassembly of center console arm rest lid
Yes, you take out those screws you are mentioning and the silver center trim piece does come off, but the "base pieces" do not come apart any further. I tried carefully prying apart the remaining pieces part, thinking they were perhaps "snapped" together, but wasn't feeling it would end well with much more pressure. Too as you mentioned I believe the remaining parts are in fact glued together. I did do a quick search on Car-Parts for a used part, and as you mentioned conditions and color matching can be tricky. I'll search ebay see what I come up with.
Thanks for replying, I've been a fan since I bought the car and found the forum in 2011, Take care.
Old May 13, 2021 | 11:47 AM
Ronman's Avatar
You can buy a used one and spray paint it the color that matches your car, the paint is available. Since it is easy to remove it will also be easy to paint. A used one will have wear and tear and then just use your silver trim so it matches.
Old May 14, 2021 | 01:17 PM
Could you tell us what the matching paint is please?
Old May 14, 2021 | 07:58 PM
Ronman's Avatar
I am just talking about the medium slate gray or dark slate gray portion of the lid. People have had success with the SEM or Colorbond paint. Those two paints only work when you spray the entire panel, they are not good for touch ups because they do not match the factory paint. I had told him to use the same silver piece.
Old May 14, 2021 | 09:17 PM
A perfect match was made up for bluecoupe, it matched his existing colour perfectly. He lists the paint supplier somewhere on this forum.
Remember that the 2004 models had a shiny silver paint and the later models had a semigloss silver paint.
British2
Sep 12, 2016 10:20 PM
sive81364
Sep 16, 2011 04:58 AM
bmorgan
Mar 19, 2010 08:20 PM
blackroadster83
Apr 14, 2009 03:12 PM
radicalrik
Aug 29, 2008 07:27 AM
