Key Fob
Old Jan 14, 2022 | 07:40 AM
Carjones's Avatar
Default Key Fob
I managed to loose my 2nd key fob and have found them difficult to locate on line like I have other cars. I'm looking for an uncut key inside a fob that I can get cut and programmed. Any suggestions?
Thanks.
Old Jan 14, 2022 | 08:43 AM
Southernscrew's Avatar
Default Re: Key Fob
Contact RoB @ Needswings.com
https://www.needswings.com/crossfire-replacement-key
Ken
Old Jan 14, 2022 | 09:14 AM
Default Re: Key Fob
Or Josh Chase at the Mercedes Swap Shop.
Old Jan 14, 2022 | 05:37 PM
Leviheim's Avatar
Default Re: Key Fob
https://www.remotesandkeys.com/produ...flipkey-remote
Old Jan 14, 2022 | 06:50 PM
Default Re: Key Fob
I'd STRONGLY recommend avoiding this company.
1) Members have tried them, and been disappointed.
2) They are, by far, more expensive than Josh or Rob.
3) Rob and Josh both own Crossfires and work hard to support the Crossfire Community.
Old Apr 3, 2022 | 05:28 PM
richb55's Avatar
Default Re: Key Fob
Originally Posted by ZERACER
Or Josh Chase at the Crossfire Swap Shop.
I think it’s called Mercedes Swap shop 😎
Old Jun 25, 2024 | 01:50 PM
bossman4's Avatar
Default Re: Key Fob
A slight hijack of the thread. I just picked up a base 2006 roadster with low miles. It has 2 key fobs and both keys will start the car, but only one key will lock/unlock the door and run the flashers. I replaced the batteries, thinking that may help, but it did not help the key fob that looks more worn.
It does not sound like as big of a problem that some folks are experiencing with their keys, but it is annoying.
Does this require the "send in" and "$250 a key" solution?
Thanks in advance!
Old Jun 25, 2024 | 03:43 PM
Default Re: Key Fob
Have you tried the procedure to resync the FOB?
Old Jun 25, 2024 | 04:00 PM
richb55's Avatar
Default Re: Key Fob
yes I was going to say similar “pairing” the key
Somebody on here will know the procedure 👍
Old Jun 25, 2024 | 04:01 PM
Default Re: Key Fob
One method.
To synchronize the key fob transmitter
This may be required after replacing the batteries or when receiving a replacement fob.
Directions as stated in the Owner Manual.
 Aim the transmitters red eye at the vehicle.
 Briefly press the lock or unlock button twice.
 Within 30 seconds, insert the key in the ignition.
 Turn the key to the ON/Run position.
The remote control function should again be operational.
Second method
PROCEDURE
Transmitter programming by the customer is done by performing the following steps: Insert the key into the ignition switch.
1. Press either the lock or unlock button momentarily twice.
2. Turn the key in the ignition switch to the ON/RUN position within 30 seconds.
Old Jun 25, 2024 | 08:58 PM
bossman4's Avatar
Default Re: Key Fob
Tried procedure 1 and 2 several times with the inoperable remote. IR transmitter in the inoperable key not functioning?
Old Jun 25, 2024 | 09:23 PM
bossman4's Avatar
Default Re: Key Fob
Sent in a query to Mercedes Speed Shop. Thanks for all the help!
Old Jun 25, 2024 | 10:30 PM
bossman4's Avatar
Default Re: Key Fob
Followed speed shop recommendations.(you tube video)
Turned out that I mixed up the new and old batteries during my escapade with one of these newer child proof battery packages. %$#$$###
At least I did not cut my finger off.
Old Mar 1, 2025 | 06:45 PM
socalcrrvs's Avatar
Default Re: Key Fob
How do I contact Josh Chase at the Mercedes Swap Shop? I googled him and only found his facebook & instagram pages.
Old Mar 1, 2025 | 08:12 PM
Default Re: Key Fob
There is this thing called "Google"..........
https://themercedesswapshop.com/
russ1ell
Sep 17, 2017 08:16 PM
rrromine@aol.com
C-I-C-C-I Technical Documentation Collection
Apr 30, 2017 09:34 AM
Fildo Dog
Jul 6, 2015 05:20 PM
RUBRDUX
Apr 25, 2015 01:12 PM
Larry Hitze
Mar 23, 2014 01:33 PM
