Big Thanks!
Old Feb 22, 2022 | 10:01 AM
Derekw66's Avatar
Default Big Thanks!
I just wanted to say thank you to everybody on the forum. Thanks for all of your articles, troubleshooting tips and pictures, I solved 98% of all of my issues on my recently acquired basket case. Just some of my issues:
Both front inner fenders and inner corners, right front headlight, idler pulley, spark plugs, front and rear pads and rotors, water pump, hood release handle, center console, fog lights, grill, lower grill guards, steering linkage, two front rims, two front tires, driveshaft support bearing, steering stabilizer, both lower ball joints, mass airflow sensor, both front springs, rocker panel brackets, wheel sensor, ABS control module which fixed my brake light, ABS light, Bas light, speedometer, odometer, rear wing stuck up, rear wing switch flashing and I’m sure one or two other lights. Relay control module, thermostat housing and thermostat . Also changed manual transmission and rear end fluid with the obligatory engine oil, coolant and brake fluid purge.
Without this forum, this car would not of been back on the road. It was destined for parts only. Now it’s my daily driver and will get a new coat of paint soon enough. It survived thanks to you guys, so thank you.
Old Feb 22, 2022 | 11:06 AM
Default Re: Big Thanks!
Thank you for rescuing one of these beauties.
Old Feb 22, 2022 | 11:18 AM
Shamrock's Avatar
Take a look at our group. https://www.facebook.com/groups/carolinacrossfireclub. Would like to have you.
Old Feb 22, 2022 | 07:11 PM
Deepsea21's Avatar
Awesome! So happy to hear it's your daily driver as mine is. I mean, what's the point of having a cool car if you're gonna keep it in a garage and under blankets all the time? Cars that sit rot from the inside out, cars that run can run for a long, long time.
jt2005crossfire
Feb 26, 2018 11:35 PM
longspoon
Aug 26, 2017 09:17 AM
skarlet
Jun 2, 2015 09:57 PM
caravanc83
Nov 13, 2013 11:38 PM
Stogey
Jun 21, 2008 06:28 AM
