Brake light work only when headlight are off
Several weeks ago I had a minor accident that involved a guide wire (fence) breaking my two front headlights and grill .I drove the car home after the accident and my BAS/ESP light came on later in the week I replaced the headlights and bulbs. The BAS/ESP light remained on afterthe repair. I tried to reset severat times by turning the steering wheel as directed in the fourm. The brakes lights function correctly when the headlight switch is in the off position BUT when I turn the headlight on the brake light do not function correctly. ( I believe they stay on).
2005 crossfire
74k
no other known issues
2005 crossfire
74k
Re: Brake light work only when headlight are off
2005 crossfire
74k
2005 crossfire
74k
on
You say all is well with lights off. Ok, got that.
NOW:
You turn light on and what happens:
--- The brake lights come on and stay on. (ICM I would think.)
--- The brake lights come on when I step on the brakes, but then won't go back off. (This would make me think there is some odd screw-up that is "latching" the brake light relay, looking at the wiring diagrams [which are incomplete and not totally accurate] the only thing I can come up with is the Antilock Controller module - but I just don't see how.....)
The CLPSSM is wired to the tail lights thru diodes, don't see how that could be it...
How can we help you if you can't tell us what the symptom is?
NOW:
NOW:
dobermann
24
05-08-2018 01:19 AM
AlexParra
12-09-2013 02:10 AM
blackoutken
01-25-2012 11:21 AM
