Stereo Removal Help!
Old Jul 7, 2006 | 06:19 PM
C0LLiN's Avatar
Default Stereo Removal Help!
Hi, I am trying to remove the stock stereo from my '04 crossfire... I tried to take the panel that is over the stereo off but it just won’t detach... I am trying to hook up my iPod adapter to the back of the stereo. Any help would be appreciated.
Old Jul 7, 2006 | 11:30 PM
Eracer76's Avatar
Default Re: Stereo Removal Help!
You need the special removal keys/tools to get it out the easy way. There are two slots, one on either side of the radio, where you insert the keys, then the radio just slides right out.
I'm not sure where you can get them. I've had my set for many years, being I'm an installer. You might be able to go to a stereo shop and have them pull it out, they shouldn't charge you much if anything, its only a 10 second job.
Old Jul 8, 2006 | 07:47 AM
crossfirefrank's Avatar
Go to a local stereo shop they will remove it. It took them 10 seconds pulling the unit and 10 minutes looking at the car!!
Old Jul 8, 2006 | 01:08 PM
CrazyInBlack's Avatar
is there a quick way to hook up an ipod? or is this some kind of fm adapter?
Old Jul 9, 2006 | 12:38 PM
Scott_lmtd's Avatar
Collin,
The Eracer76 is correct, go to your local shop, tell them to use the VW keys (make sure they push all the way in) and click it's out. Might want to get your own set, it's worth having if you are going to any work behind the unit.
Crazyinblack: Simple answer is NO. Read the posts, many have looked, some have tried, no way to interface anything to the head unit expect the factory multi-cd unit.
syfi
Mar 28, 2026 04:14 PM
TerryR
Dec 13, 2019 03:27 PM
o55ie18
Oct 5, 2015 05:50 PM
brandoni
Sep 30, 2015 07:48 PM
Wisconsinfdcrossfire
Sep 20, 2015 10:04 PM
