Climate Control electrical issue
Old Apr 18, 2007 | 12:52 PM
RobW's Avatar
Default Climate Control electrical issue
Not good guys and gals...Got in my car this morning and drove about a mile or so with the heat on during this cold April. The car had a sudden hesitation at the same time that I noted that my fan on the climate system slowed/then sped up. After a few seconds I smelled burning insulation. I immediately shut the system off but the smell of ozone (burning isulation) was overpowering. I continued to drive with no apparent problems with "drivability". About 4 hours later on my way home I tried it again and it seems that it starts okay and then must be drawing too much current or something because the smell returned and the fan went way down in speed.
My questions are whether anyone has had this problem? AND If it is burning out the wires from a short in the motor why isn't the fuse blowing instead of the wiring? Last I checked, having wiring as your "fuse/breaker" was a bad thing.
Old Apr 18, 2007 | 04:48 PM
spensley's Avatar
Default Re: Climate Control electrical issue
Have you had the TSB done on the fan (I think it's the fan - somebody will correct me)?
Old Apr 18, 2007 | 05:13 PM
bobs's Avatar
That was for the radiator fan, not the A/C blower.
Old Apr 18, 2007 | 09:07 PM
stryfox's Avatar
If your under warranty take it in.
If you are out of warranty take off the bottom cover of the heater box and inspect the blower motor for foreign material.
The recall had nothing to do with the heater blower motor.
It was for the cooling fan.
Old Apr 18, 2007 | 10:23 PM
04Fire's Avatar
Take it in! That sounds as if something foreign is cought in/on the fan motor... I took mine in because it was shorting out and they replaced the whole control unit.
Old Apr 23, 2007 | 08:28 AM
shrek_au's Avatar
Same things happened on my SRT6 ('O5), I had the control system and AC unit replaced under warranty and it fixed the issue...if only I could get the same done to the gear box.
Old Apr 24, 2007 | 12:36 PM
RobW's Avatar
Well the word from the dealer is that the fan motor seized and a resistor went bad. Should get it back tomorrow.
northwest_crossfire
May 30, 2016 05:19 PM
ldare2000
Dec 29, 2015 07:57 PM
x1xsinisterx1x
Aug 24, 2015 07:31 PM
BrenLW
Aug 5, 2015 04:53 AM
MAXIMUM
Aug 4, 2015 11:04 PM
