Electric Seats
Old Aug 20, 2015 | 07:41 AM
ldare2000's Avatar
Default Electric Seats
Hi,
The electric seats on our Crossfire don't always work. I've searched the forums and people have said "oh it's a loose connection somewhere" but I don't think that's true for me.
Sometimes my seats work sometimes they don't. Sometimes they come back to life by themselves. However if I need to adjust and they won't I can disconnect the battery long enough for the clock to loose it's memory then the seats work again.
Does this suggest some kind of computer related issue?
Cheers
Louis
Old Dec 28, 2015 | 09:56 PM
MrFister's Avatar
Default Re: Electric Seats
I have the similar symptoms, either both work or both refuse to operate. Have you been able to track this down?
Steve
Old Dec 29, 2015 | 07:57 PM
The most common issue is fractured solder on the little circuit board that is part of the seat relay which is down under the dash. This will cause the seats to move, then refuse to move, then move at times - then quit again - with no rhyme or reason. This is such a common issue, we usually fix a few relays at our meets in North Georgia -but unless you are experienced at SMD solddering, you are way better off just to spend the $30 and order a new relay.
Order a relay and change it yourself!
Click here:
https://www.crossfireforum.org/forum...eat-relay.html
Valk
Jul 12, 2021 09:49 PM
steps
Apr 26, 2016 06:21 PM
Charlesl
Sep 30, 2015 10:46 PM
steps
Sep 19, 2015 10:43 PM
westonrose
U.K.
Sep 16, 2015 02:22 PM
