port and polish?
Old May 13, 2007 | 10:10 AM
tashspop's Avatar
Default port and polish?
has anybody looked into the heads on these cars? maybe a port and polish or opening up the runners a bit? just wondering and are the other mbz 3.2's like in the c class cars the same engine? maybe there are plenty of juck yard jewls out there.
Old May 13, 2007 | 10:57 AM
Default Re: port and polish?
Maybe you should change the title on this thread.
Old May 13, 2007 | 11:14 AM
andrew's Avatar
-C-I-C-C-I Associate Member
~ agreed and changed... a bit more appropriate.
Old May 13, 2007 | 02:54 PM
HDDP's Avatar
http://www.gethoned.com/
Old May 13, 2007 | 03:19 PM
Maxwell's Avatar
there is no such thing as a junkyard Mercedes, I've never seen one in my life, not even a mangled up wrecked one.
I would try ebay and look for used heads. I don't recommend the abrasive media porting, its doesn't really work, and its very expensive. You best bet is to find a machinist who uses a 5 axis mill and has a good history of porting heads on a cnc. Most likely he will know where to take out material and where not to remove material, this is the problem with the abrasive media, it removes all material equally through the port runners, which is WRONG! You don't want this because you will loose air flow velocity in certain sections, which might cause a bog or a lag time while it waits for velocity increase. This is why you need to find a professional who does it for a living and has cnc for consistency in cutting. You will end up paying for a lot of work, not worth the effort unless your going to sell 3.2 MBZ heads, and then you might as well keep going and cut larger valves with improved valve angles. Trust me you will end up mortgaging your house and your wife will leave you. lol.
The extrude hone is really only good for intake manifolds and maybe cast iron exhaust manifolds, it's not used for heads.
Your best bet is to supercharge the engine, its cheaper and easier, and there are more pro's out there who understand the technology better, so you will be up and running sooner with less cost to you. worst case scenario you will end up spending at least $5,000.
Old May 13, 2007 | 03:33 PM
HDDP's Avatar
Old May 13, 2007 | 03:36 PM
intenseblu's Avatar
i've dealt much with Modern Performance ... very professional bunch, and can always count on Cory (owner) to take real good care of you.
Old May 14, 2007 | 08:30 AM
tashspop's Avatar
sorry about the original title, i wasn't even thinking there. anyways, i'm just looking at all performance options as i know nothing about my new drivetrain. i do know that it took about 2 days worth of driving and i wanted more power.
Old May 14, 2007 | 02:58 PM
Maxwell's Avatar
I hear that, you might want to look at the SI reprogram or, a NOS kit or S/C. I wouldn't recommend porting your heads, it is a science. You just can't pump an abrasive media through it and expect a good power band.
Old May 15, 2007 | 08:41 AM
tashspop's Avatar
nos is way out of the question. i'm not into tearing up a new motor. i'm guessing there are decent results from the si reprogram? by s/c do you mean supercharger? i'm guessing your talking about a custom build, because i haven't seen any kits available except that $14k one.
Old May 15, 2007 | 04:48 PM
Maxwell's Avatar
Do the SI thing first, its a bit expensive but hey, your getting another 20 whp, not a bad upgrade for $550 - $600. Then if possible I would install the srt6 exhaust, if cheaper have a muffler shop built one. Then buy the large intake system from the SL55 MBZ, (not sure if this is the correct model, do a search) it has larger intake volume and larger air filters. All together this should step you up a notch in the Hp area, maybe 35-40 hp, and a good boost in torque too. should run ya about $1,100 total.
Next I would start looking for bigger brakes, definatly the SRT6 set-up is the way to go. Then some braided lines, and grippy brake pads. DIY it for about $2,000 +/- $300.
The rest of you money should be spent on handling parts. AMG or SRT6 sway bars, coil overs, Rims, tires, etc...
After this you will have to do a custom S/C for the crossfire, but I heard a rumor on another thread here that an aftermarket company is in the works.
Oh yeah if its an automatic get the Sprint Booster $300.
Old May 24, 2007 | 07:53 PM
Maxwell's Avatar
found some cool pix of some E55 heads, check em out. they are suppose to be ported, but they don't look CNCed, probably some hack with a carbide cutter doing a hand job, found this on the mercedes forums.
smfrycruzr
Jul 17, 2023 05:33 PM
rfourt
Aug 12, 2020 07:27 PM
Mackel
Sep 29, 2015 02:41 PM
RacerXofFL
Sep 15, 2015 05:00 PM
velociabstract
Aug 28, 2015 11:20 PM
