JVC KD-NX5000 in Crossfire
Old May 15, 2007 | 08:37 PM
ashwats's Avatar
Default JVC KD-NX5000 in Crossfire
Has any one installed a JVC KD-NX5000 in Crossfire coupe?
Please post your pictures. And write your experience.
Thanks.
Old Jun 10, 2007 | 03:07 PM
RuKidding's Avatar
Default Re: JVC KD-NX5000 in Crossfire
I've been watching these on e-bay looks like a great radio and fix's the issue with the cd-changer location. Been waiting for someone that is a audio guru to leave a post.
Old Jun 19, 2007 | 04:27 PM
fflores's Avatar
I just put in a order for one... should be here by the end of the week.
Old Jun 19, 2007 | 06:09 PM
ashwats's Avatar
Are you planning to get it professionally installed or yourself ?
Old Jun 19, 2007 | 07:25 PM
GatorLCA's Avatar
I'm not a fan of throwing a black-faced unit into all that silver. Now if I were to get the dash in the carbon fiber trim that'd be a different story. I hate to ruin the feng-shui of the interior.
Old Jun 19, 2007 | 07:45 PM
fflores's Avatar
I believe you just need a set of special wrenches that go in the slots at the corners of the stock radio... after you pop that, i believe the radio just pulls right out. I am going to try to install it myself... I installed with a buddy of mine my Pioneer AVIC-D2 6" x 4" touch screen GPS navi... it was a pretty stealthy install... the gps and xm antenna were put in the sun roofs track, so you couldn't even tell that i had xm or gps navi systems in the car.
Old Jun 19, 2007 | 08:58 PM
ashwats's Avatar
Wow... i would really appreciate if you can take pictures through out the project and post it here. I believe the GPS need some kinda interfacing with the vehicles speed sensor? And there is an antenna for GPS to be installed under the dash? Are you planning to install a rear view cam? I wish JVC makes a Silver faced one too...
Old Jun 20, 2007 | 02:05 AM
fflores's Avatar
Sure, i'll take pics... yes you usually have to hit a speed sensor wire, If that becomes a problem then i'll just take it to a audio shop. Here is a question, when you have a stock GPS navi from chrysler, i am assuming that the harness that connects to the back of the GPS HU has the speed sensor already hooked into the stock harness...
As for the GPS antenna i will see where i can hide it, i do not want to put it on the exterior of the car.
Should be here on Monday.
Old Jun 22, 2007 | 11:59 PM
fflores's Avatar
Ok, i spoke with some of the people over at best buy, i wanted to pick up a universal harness for when my GPS HU arrives, then this is when a couple of issues came up.
But first i have couple of questions, I have a 2005 SRT6, does the stock audio system come with a amp? If so, it might not be as easy as just using a universal harness to hook everything up. If that is the case, then it will be a little more difficult of a job to get this HU to work with the SRT6, however they said that it would probably only be $100 more in labor and parts if i was to go with Best Buy and have then install it. Which isn't a big deal.
More to come.
Old Sep 28, 2007 | 09:01 PM
SRT6nTulsa's Avatar
Smile Pictures of my JVC KD-NX5000 in Crossfire
Here's 10 Megapixel super high resolution pictures taken of my installation. Navigation, bluetooth, and Sirius all installed successfully. I like the navigation much more than my TomTom.
It was definitely a good investment. I would recommend it to anyone with only a single din slot.
http://www.alexbax.com/Projects/SRT6/JVC1forForum.jpg
http://www.alexbax.com/Projects/SRT6/JVC2forForum.jpg
http://www.alexbax.com/Projects/SRT6/JVC3forForum.jpg
http://www.alexbax.com/Projects/SRT6/JVC4forForum.jpg
Old Sep 28, 2007 | 09:22 PM
SRT6nTulsa's Avatar
Default Re: Pictures of my JVC KD-NX5000 in Crossfire
Oh, and another thing...the DVD playback is incredible!
Old Sep 29, 2007 | 05:45 AM
radmanly's Avatar
Where did you put the GPS and satellite radio antennas?
Old Sep 29, 2007 | 10:00 AM
GatorLCA's Avatar
If it comes with one like the XM/Sirius units do you can easily place it on top of the car by the hatch then feed it through the panels to hide the wiring until you get by the passenger seats, not too hard and it keeps it clean.
BTW, the pics look great, it's too bad it doesn't come in a silver.
and if you have satellite radio, could you take a picture of the display on any channel...my display only shows the artist or title and not both (kind of annoying).
Old Oct 13, 2007 | 06:06 PM
SRT6nTulsa's Avatar
I put them in the back window, between the metal and the glass. I fed them through the left side grommet.
Old Oct 15, 2007 | 08:16 AM
matadorCE's Avatar
How was the install? I've put in many regular decks but never ones that have navigation or DVD playback.
Old Jan 15, 2008 | 10:16 AM
fromm's Avatar
SRT6nTulsa, did you have any challenges installing the KD-NX5000? Was the opening in the dash adequate for the unit? Could you take a picture of the antenna location? Did you wire it to the factory amp or run new speaker wire?
I'm preparing to buy my first Crossfire, a 2007 Limited Coupe. I have to replace the deck immediately because I must have Sirius. I'm a huge control freak so I need to make sure I won't have any major hurdles before I take the plunge.
Old Feb 3, 2008 | 12:41 AM
SRT6nTulsa's Avatar
Smile Re: JVC KD-NX5000 in Crossfire
Here's the new location of the SIRIUS and NAV. I even get signal inside my garage.
Old Feb 3, 2008 | 07:47 AM
radmanly's Avatar
Nice. Very clean.
Old Feb 21, 2008 | 05:20 PM
redlinedrummer's Avatar
Just bought a 2005 SRT6 with 118 original miles . Looking to install the JVC KD-NX5000 in the next few weeks and need some answer for a few things.......Where's the VSS located and what does it look like? Will the factory amps in the car work with the Unit?
Thanks
Old Feb 27, 2008 | 11:18 AM
fflores's Avatar
Thanks
The wire is the pink line off of the Amp.... The amp is located along the foot well on the passenger side of the car.... Top into that for the speed sensor.
