Help!! ACC Switch not working?!
Old Aug 5, 2007 | 10:39 AM
nox1s's Avatar
Default Help!! ACC Switch not working?!
So I installed my aftermarket headunit around 1/2 year ago - maybe even longer, and everything has been working fine. Yesterday I pull into a mcdonalds parking lot and my headunit + drive and play (ipod) power goes out.
I'm stumbled, it seems when I connect anything to just the direct power source it works fine. But when I connect it to the switched power source (when the car turns on) nothing works.
I also put back my stock headunit and the same thing, I started my car and it did not turn on , I had to push the power button for it to turn on.
I checked the fuse box and as far as I know all the fuses looked fine to me (unless there is more then one box?! There were only like ~ 7 fuses in there)...
This really sucks, i'm not sure what could've caused this or whatnot, but having to turn off my radio / drive+play every time I turn off my car, and vice versa isn't ideal for me.
Any suggestions, please!?
Old Aug 5, 2007 | 05:59 PM
CrossfireLTD's Avatar
Cool Re: Help!! ACC Switch not working?!
There are 2 fuse panels, one under the hood and one on the driver side on the side of the dash. Take a look at the owners manual to find out what fuses are where.
Old Aug 6, 2007 | 12:54 PM
nox1s's Avatar
Default Re: Help!! ACC Switch not working?!
Thanks a lot! I replaced the fuse and it worked perfect.
I'm confused as to why it would now decide to blow - after such a long time of working fine..
Old Aug 6, 2007 | 04:21 PM
bobs's Avatar
Sometimes fuses can do that after prolonged exposure to motion/vibration. That's one of the reasons aircraft have circuit breakers instead of fuses. I'd say don't worry about it. Now, if the fuse blows again, I'd say you might have a problem. Time to break out the wiring diagram and the ammeter and start looking around...
Old Aug 6, 2007 | 09:33 PM
apkano's Avatar
Life is random...so am I.
Did you add of change any wiring, or was it pretty much a plug-and-play unit using all the existing wiring?
Old Aug 6, 2007 | 09:57 PM
nox1s's Avatar
I didn't change anything, I used the supplied harness, hooked up all the wires, and it worked fine.
Just after all this time it decided to break... hrm.
Maybe the vibration did it or something.
Old Aug 7, 2007 | 07:26 AM
apkano's Avatar
Just curious...a lot of times people will install new items that require wires to be added or re-routed. If they have to pass through any metal items, they won't use a grommet. Many times this leads to their problems.
pioneer4x4
Oct 6, 2018 01:09 AM
waldig
Jul 31, 2017 09:46 AM
axnguyen
Jul 21, 2015 11:41 AM
66L72M21
Jul 15, 2015 04:23 PM
gtjl
Jul 8, 2015 07:42 AM
