Question about the dip stick
Old Oct 11, 2007 | 01:23 PM
darkXf1r3bill's Avatar
Default Question about the dip stick
I bought my car from carmax about 3 months ago and i just want to make sure they put enough oil in. When looking at the dip stick its got a "min" and a "max" and right in between is the measuring bar. My oil with a semi cooled engine takes up 50% of the bar between min and max. Is this enough?
The oil (now 3,000 miles later) looks a little dark. I was thinking of putting in 8.5 qts of either 5w-40 or 0w-40 just to be safe. You just never know what's in your cars engine if somebody else does it.
Thanks in advance.
Old Oct 11, 2007 | 02:14 PM
aschrager's Avatar
Default Re: Question about the dip stick
Check the owners manual it tells you how to check the oil with out opening the hood.
PS - I would change the oil and use 0-40 mobile 1. Just put in 8 qts. It will be full. A dry engine takes 8.5.
Old Oct 11, 2007 | 03:23 PM
msheredy's Avatar
That's perfect.
Thanks in advance.
If you pulled a Carfax you should see when it was serviced last and gauge the time frame from there. When in doubt change it out, with 0w-40.
Old Oct 11, 2007 | 05:08 PM
You guys have been very helpful. I love a forum where you can get fast easy answers. Thanks!
TerryR
Dec 13, 2019 03:27 PM
Sterling57
Apr 11, 2016 06:11 PM
jimf
Oct 10, 2015 10:22 AM
Charlesl
Sep 30, 2015 10:46 PM
brandoni
Sep 30, 2015 07:48 PM
