Srt Instr. Cluster Swap
Old Nov 4, 2007 | 08:00 PM
CALL911's Avatar
Default Srt Instr. Cluster Swap
Does anyone know if an srt 6 instr. cluster will work in a limited ? Saw one on ebay a while ago, and thought it would be a nice upgrade if it was just "plug and play".
Old Nov 4, 2007 | 08:45 PM
04Fire's Avatar
Default Re: Srt Instr. Cluster Swap
I'd agree, that 200 mph speedo would be pretty cool.
Old Nov 7, 2007 | 09:38 AM
Maxwell's Avatar
I've heard of a couple slk's out there that swaped the stock cluster for a Crossfire instrument cluster, but I'm not sure if anyone has tried the SLK instruments in a Crossey.
Old Nov 7, 2007 | 10:41 AM
BrianBrave's Avatar
<--- Huge Horsepower
I doubt it would make your Limited go 200 MPH.
I am not sure if the Speedo needle would indicate the correct speed on the dial face has the numbers for the SRT-6 are scaled different and the signal to the needle would not compensate.
Old Nov 7, 2007 | 05:54 PM
CALL911's Avatar
Possibly would have to change the speed sensor as well ?? Or is it internally regulated in the cluster assy. ?? Or is it controlled by the ECU ?? I would hate to buy one and not be able to use it. I'm just a poor civil servant. This is the first new car i've ever owned ! THANKS FOR THE INPUT !
Old Nov 7, 2007 | 05:58 PM
LantanaTX's Avatar
If the price isn't too high I would be willing to buy it and give it a try.
Old Nov 8, 2007 | 09:22 AM
malcb's Avatar
Text below is from the Service Manual (not SRT6) - SRT manual has the same text and pictures of the 160mph dial - page 8J-59! Dash is a complex bit of kit - for instance the instrument cluster includes the FSS which calculates the service interval with information supplied over the CAN data bus from the CAB - Controller Antilock Brakes and PCM - Power Control Module!
CAN data required for the FSS indicator:
4 WSS signals for calculating vehicle speed and distance from the CAB
Coolant temperature from the PCM
Engine speed from the PCM
Load torque from the PCM
Speedo is actually driven over CAN data bus by the CAB. The speed displayed might be from the front or the rear, if the car is cornering it will use the front (an average I suppose?) if car is not turning but there is a rear wheel spinning that will be used as the highest wheel speed is then displayed!
Doesn't help determine if the SRT dash will work, I would guess it might - be ready to connect a lot of plugs though!
I am amazed if a Crossfire dash worked in an SLK - if it does it's a testiment to Chrysler / MB that they didn't need to change any devices so much that they wouln't comunicate! If it did work with the SLK's different wheel sizes I suppose it suggests the speedo change would work.
The instrument cluster includes four analog gauges.
1.
Speedometer The speedometer has a 0–160 Miles Per
Hour (MPH) primary scale with Kilometers Per Hour (km/h)
on the secondary scale. The speedometer receives wheel
speed data from the CAB via the CAN data bus and can be
verified by comparing the speed signal viewed by the
DRBIII
T from the wheel speed sensors (WSS) and the output
seen on the IC. The Electronic Stability Program (ESP)
indicator lamp located between the left and right turn signals
in the speedometer face illuminates when it is activated
by the Controller Antilock Brake (CAB), indicating the
need to adjust driving behavior to the prevailing road conditions.
Also located in the speedometers face are the trip
odometer and the Flexible Service System (FSS) indicator/
odometer (1). To the right and left of the speedometer face,
mounted in the IC, are the rotary dials (2-3) for the FSS
and the digital clock.
Old Nov 26, 2007 | 06:36 PM
ppro's Avatar
IF the cluster includes the vehicle mileage there's probably a tie-in to the on-board computer to prevent tampering of mileage. My guess would be that the speedo itself is probably plug and play but the swap would be complicated by the need to deconflict the protection on the odometer. Probably a dealer type of thing where they certify the odo to the correct miles and do something to make it work with the on-board computer. Almost worth it to see the look on people's face when they glance at the speedo and see the (theoretical) max speed...
ppro
Old Nov 30, 2007 | 07:25 PM
CALL911's Avatar
There is another srt6 speedo on EBAY. Price is $199. I'm tempted again ! What about the warranty ? I've only got 4,000 mi. on mine, and I'd hate to void the warranty. The one on EBAY has 5,000 mi. so I would just wait until 5,000 mi. to do the install. THANKS FOR ALL THE INPUT.
Old Mar 2, 2008 | 07:46 PM
JMann101's Avatar
Any updates on this?
rmcdaniel12
Sep 26, 2016 05:37 PM
RED DOG
Aug 14, 2015 01:24 AM
Jul 25, 2015 08:01 AM
Jerrysrt6
Jul 24, 2015 09:15 PM
Romio
Jul 24, 2015 07:04 AM
