Adding Castor oil to your fuel
Old Dec 11, 2007 | 07:48 PM
Maxwell's Avatar
Post Adding Castor oil to your fuel
stumbled accross this article today, in regards to adding castor oil to aircraft and automotive fuels.
http://www.wipo.int/pctdb/en/wo.jsp?...6&DISPLAY=DESC
I know the castor oil improves cylinder piston seal against the rings, so your cylinder pressure should increase, not to mention the benifit of more lubrication. They also mention emisions are also reduced.
their testing showed a 25% increase in MPG. I think I will have to order some Castor oil and a quart of Klotz race oil, and try this for an experiment
Old Dec 12, 2007 | 05:51 AM
crossbowme's Avatar
Default Re: Adding Castor oil to your fuel
Actually, castor oil was the standard lubricant in WWI. They mixed it in the fuel like you would for a chain saw or outboard. You still find it today in R/C and aircraft engines built in 3rd world countries.
I have flown aircraft using castor oil and it is not a pleasant experience. It makes you sick!
Old Dec 12, 2007 | 07:42 AM
Maxwell's Avatar
we'll see what happens, I might use a synthetic race fuel oil instead, but castor oil is cheap, and they where only using 1-2 ounces in the test, so smell is not an issue
Old Dec 12, 2007 | 09:08 AM
apkano's Avatar
Life is random...so am I.
So castor oil is supposed to help your rings seal against the cylinder wall, thus improving your compression...funny...I didn't think castor oil was viscous enough to plug up the ring end gaps!?!?!
Old Dec 12, 2007 | 09:31 AM
Maxwell's Avatar
no, it's not sealing the ring end gap, but making a tighter seal around the ring surface that contacts the cylinder on the compression ring.
Old Dec 12, 2007 | 04:44 PM
Maxwell's Avatar
these guys are seeing a 2 mpg increase, not bad for only pouring in 4-8 ounces of oil! that will easily offset the cost of running premium for those cheap bastards out there. Just calculate the fuel savings for the year, not a bad trick! this could pay for a new set of tires.
http://www.rx8club.com/showthread.php?t=99636
Old Dec 12, 2007 | 06:37 PM
apkano's Avatar
I see...you're going to run oil into your combustion chamber along with the fuel so you can make a better seal with the rings...even though there's a HUGE RING END GAP!
Kind of like I said before!
Old Dec 12, 2007 | 07:44 PM
Maxwell's Avatar
well the end gap doesn't have nearly as much surface area for leakage, when compared to the entire circumfrence of the piston ring.
in the link to the arcticle I posted in the first post, they did testing on a Pontiac 3800 v6, and also gained 15-20% improvements. I just found it interesting
Old Dec 12, 2007 | 07:55 PM
DrMike's Avatar
Will it not crass up the injection system , very very expensive replacing those little suckers..
Old Dec 12, 2007 | 08:06 PM
Maxwell's Avatar
It shouldn't but I'll find out if it does I wouldn't mind swapping in some srt6 injectors, for when I do the ecu flash. so I'm not worried about the stock injectors.
Actually I'm going to start with 4OZ. /10 gallons, then on the next tank mix 8oz./10gal fuel. currently I'm getting 17-18mpg, so we'll see what happens
Old Dec 13, 2007 | 06:37 PM
DrMike's Avatar
Mine is stored, it doesn't stop snowing here, at least another foot on the way...
I will give it a try in March when this crappy weather goes away...
Old Dec 13, 2007 | 06:40 PM
Maxwell's Avatar
tonight I will pour in 4 oz. of regular 2 strroke oil and test that out, but I will order up a gallon of Klotz Benol next month.
Old Dec 15, 2007 | 09:58 AM
arado's Avatar
Castor bean oil was an excellent lubricant in the old days. We used it racing motorcycles. However, it leaves some nasty residue and does not mix with other types. I will use nothing but Mobil 1 in every engine/transmission I have. Gary
Old Dec 15, 2007 | 03:18 PM
Maxwell's Avatar
yeah, your right the Castor oil will case issues with carbon build up, but maybe not so at 300:1 mix, either way I will be using Klotz synthetic two stroke oil intead just to avoid any carbon build up down the road.
I'm still on my first tank full right now, so maybe by the end of the week I'll have some numbers.
Old Dec 17, 2007 | 05:45 AM
simon-srt6's Avatar
When your rings get all glued up, you will be sorry......Also if you add oil to your feul you will reduce the RON so a less powerful burn will mean less power.
2 stroke engines work well for this, but even then you need to strip the engine to clean the rings.
Old Dec 17, 2007 | 06:22 AM
HJM's Avatar
HJM
What about emission levels? it doesn't mean it is harmless for our high performance engines. In the good old days the compression ratios where a lot lower and hence the thermal stress!
Since it is a natural product
Oil should not be present in the combustion chambers! The combustion by-products can be harmful not only to the environment but also to your engine.
This sounds like one of those snake oil inventions again.
HJM
Old Dec 17, 2007 | 12:44 PM
Maxwell's Avatar
it won't hurt emmisions, and the synthetic stuff doesn't get gummy. I'm still experimenting, and have a couple more tanks to fill up.
Valk
Jun 22, 2025 09:15 PM
TerryR
Dec 13, 2019 03:27 PM
Oct 1, 2015 01:42 AM
Sep 28, 2015 07:40 PM
stlas69
Sep 14, 2015 06:45 PM
