say it ain't so...
Old Feb 6, 2008 | 04:07 PM
Canyon Driver's Avatar
Default say it ain't so...
so i replaced my plugs yesterday and found some disturbing stuff... both plugs from one of my cyliders were totally oil fouled. please tell me that these cars have some common simple issues with fouling plugs! i'm gonna pull the compression and check the vacuum for flutter this weekend but i'm scared to see the results as this seems to be my luck with cars in general. and B4 you ask, no, its no long under warranty. /palmforehead
Old Feb 6, 2008 | 04:12 PM
RPM's Avatar
RPM
Moderator
Default Re: say it ain't so...
How many miles do you have on it?
I have not heard of this issue.
Old Feb 6, 2008 | 04:49 PM
40k miles and as a side note it stumbles at idle.
Old Feb 6, 2008 | 05:30 PM
sonoronos's Avatar
Do the compression and vacuum test. I think you have the right idea. I doubt it's the cylinder rings on a 40k car. More likely that it's the valve stem seals.
I could be wrong...
Old Feb 6, 2008 | 06:02 PM
apkano's Avatar
Life is random...so am I.
Let me guess..........cylinder number 6?
Old Feb 6, 2008 | 09:05 PM
Maxwell's Avatar
I have seen a puff of smoke from my exhaust one morning, it was sitting for a couple days and I only have 25k miles. I wonder if we will be seeing some issues sooner than 100k miles?
Old Feb 7, 2008 | 03:54 AM
Stogey's Avatar
If you see blue smoke on start up, it's more than likely valve stems are leaking by a lil oil as the car sits. Do the compression and vaccumn tests. The stumble at idle is probably the fouled up plugs. That would be my educated guess.
Just my Dos Centavos !
Old Feb 7, 2008 | 10:48 AM
haven't noticed any smoke upon startup but i'll be looking for it now. the center cylinder on the passenger side had the offending plugs. and the stumble at idle has continued even though i've now replaced the plugs. i'm crossing my fingers that its valve seals, but i'll know this weekend after i do the vacuum/compression tests.
assuming that this is a valve related issues, does anyone know weather or not theses cars have permenent valve guides or are they the removable sleeved type?
thanks for the imput guys
Old Feb 7, 2008 | 04:46 PM
apkano's Avatar
That's the same area where the valve covers end up leaking......I'm starting to wonder if there's some sort of pressurizing problem in that area?
Old Feb 8, 2008 | 11:41 AM
xfire2005's Avatar
From what I see in AllData they appear to removable and replaceable.
Old Feb 8, 2008 | 12:17 PM
Stogey's Avatar
Are you sure it's not an ignition issue if you replaced the fouled plugs and still has a miss ? I'd recheck the plugs you just replaced.
I'm hopin it's not valve guides with yours havin 40K and mine havin 50K
Old Feb 8, 2008 | 05:03 PM
Shawnkey's Avatar
Time to port and polish, open up that exhaust port!
Old Feb 9, 2008 | 01:11 AM
i'll be pulling the compression and of coarse rechecking the plugs in question this weekend. i'll be sure to let you guys know what i find. thanks for helping me mind F*** the issue a bit B4 i lay into it.
Russcross
Apr 27, 2016 06:55 AM
BibaResto
Jul 4, 2015 03:20 PM
chturner
Jun 23, 2015 07:21 AM
62thunderbird
Aug 16, 2007 11:05 PM
MARK_UK
Sep 1, 2003 06:10 PM
