After market seats and air bags
Old Feb 29, 2008 | 01:49 PM
ZORRO's Avatar
Default After market seats and air bags
I would like to install aftermarket seats, but I have been told that to do so will give me an airbag warning light. This all started when I was talking to the sales people at a seat shop. They told me I might get this light and if so I would have to get the dealership to turn it off.
It seemed to me that I should make sure the dealer would do this before buying the seats and making the mounts. The dealer that has always been nice to me and never given me any problems, said no way. They explained that if the light was turned off and something else went wrong with the airbag system I would not be able to tell. They said even if they did it for me they would be afraid of the liability from the next owner. They said I should talk to Chrysler and see if I could get a waiver. Chrysler said no. Big surprise. They also pointed out that if I managed to turn the light out I would be liable if the airbags failed and someone was hurt.
Help
1. Is the seat really wired to the airbag?
2. If so, is there some way to make the car think the stock seat is still there?
3. Is there a pressure switch in either seat?
4. If there is a pressure switch where the heck is it? Can I move it to a new seat?
5. Is the stock seat really leather over plywood like it feels?
I have done a search and found these post.
Originally Posted by scot1981
yes, one of the wires under the seat is related to the airbag, i had a wire that rubbed through and it caused the light to come on. dealer replaced the little harness and that fixed it. so you might want to pull the seat back out and double check the connections, if not then take it in and see if they will fix.
Originally Posted by HDDP
I put Sparco Pro2000's in my car about 6 months ago... You'll have to do some fabrication for the brackets, but if you do it properly, they'll bolt directly into the existing seat bolt holes...
Also, you'll have to fabricate an attachment for the OEM seatbelt if you plan on using the existing seatbelt. I installed a Schroth 5 point racing harness in both seats and removed the OEM harness. If you start f'ing around with the seat belts, make sure you remove the negative battery terminal to prevent accidental deployment of the airbags...
Also, you'll have an airbag warning light come on afterwards, because the OEM seats have a pressure sensor in them and a circuit that runs through the power harness to the seat belt retainer that attaches to the side of the seat.
You can turn the warning light off with a DRBIII scan tool after you've done the install...
The entire process, including fabricating the attachment brackets took me a weekend and a case of beer...
Comments please.
Zorro
Old Feb 29, 2008 | 02:09 PM
irwin's Avatar
Default Re: After market seats and air bags
There are no pressure sensors in our seats the only wires that come from the seat would be for the seat heaters or power adjustment. those 2 things can be added to your new seats if you choose to add them or if they come equipped that way but some splicing may be required. the wiring harness for the airbag is connected to the seat belt. if you retain the use of your factory belts this would not be an issue. i have performed this modification myself, i retained the factory seat belts and never had a single light come on. my vehicle was recently serviced and scanned and my ecu was replaced by the dealer due to a crank position sensor not being able to be read. the light never came on with the new ecu and none of the technicians experienced any issues with anything related to the air bag or other safety equipment. short of wrecking my car and deploying my airbags to make sure there is no issue, i have no issues Lil. again i never had any lights come on with my old or my new ecu.
Old Feb 29, 2008 | 02:39 PM
irwin's Avatar
first pic to verify it is a real stock seat (no second guessing) and the second pic is of the only cable under the seat and it is the manual lumbar adjustment cable (its like a hood realease cable, or a brake cable on a bicycle). these seats did not have power adjust or seat heaters so absolutely no wires!
Old Feb 29, 2008 | 02:48 PM
irwin's Avatar
and yes my arm is faster than your car lol.
Old Feb 29, 2008 | 02:59 PM
irwin's Avatar
are we done now?
Old Feb 29, 2008 | 04:55 PM
ZORRO's Avatar
That is a stock Crossfire seat? Is that from the base model? It has lumbar support? Are they comfortable? Are they black? Are they for sale?
Old Mar 1, 2008 | 11:12 AM
irwin's Avatar
yes its from the base model thats why it doesnt have any power options... yeah i would sell them they are black cloth.
suelo
Sep 18, 2015 05:01 PM
westonrose
U.K.
Sep 16, 2015 02:22 PM
81's
Sep 13, 2015 04:34 PM
jaesa
Sep 7, 2015 01:50 PM
