Easy Fix: Door Speaker Rattle
Old Mar 24, 2008 | 09:38 AM
sparks81's Avatar
Default Easy Fix: Door Speaker Rattle
My right door main speaker has been having a rattle noise to it for a little while now, and it was driving me nuts. The speaker was ok, I just hated hearing something rattle in the door when I'd go over a bump in the road, or the bass would be thumping.
I read a few articles that I'd have to take off the door panel to get to the speaker, which I figured was the culprit based upon some minor "thump" tests (kinda like testing the ripeness of a melon).
I printed the sheets from the manual on removing the panel, and was starting the process. These are not the easiest instructions by the way, so I was thinking I was looking at some time investment. Go slow, don't mar the panel, fixtures, etc.
I got to looking at the chrome ring around the speaker, and took it off on a slight whim. Noticed the grill was snap in also and got it off in 2 seconds. Viola, there's the speaker and mounting screws.
Tightened all 3 screws on the speaker, cranked the stereo, and checked my work.
No rattle.
Put everything back together and took it for a road test.
Still no rattle.
I'm good to go.
Time to fix: 5 minutes (had to find the right song on the CD and listen to the song all the way through to be sure, but time does not include road test).
Old Apr 20, 2008 | 06:19 PM
nox1s's Avatar
Default Re: Easy Fix: Door Speaker Rattle
No rattle.
Still no rattle.
I'm good to go.
I was getting the same rattle, and I did that... still no fix. I know it's not my speaker blown / etc because it rattles when I go over a bump with my volume on 0!! Drives me insane, I'm hoping my dealer will replace it, but it's sporadic and try explaining that to them
Old Apr 20, 2008 | 06:48 PM
MI1XFIRE's Avatar
Try taking out the speaker and road test without it. I have heard this on other speakers, the cone can still move with the sound offwhen you driving down the road and if it isn't perfectly centered it will rub and give you an annoying squeak. If that's the case , the speaker is bad.
Old Apr 27, 2008 | 05:58 PM
smokey847's Avatar
When I "crank it up," there is a rattle or (for lack of a better word) a crackle coming from the passenger side whenever the radio is played at pretty high volume. It is really hard to tell if it's coming from tweeter or the mid-speaker. It's almost like:
You know your little pretty cheap shelf stereo system with the 3-disc changer and double tape player? You know how it sounds crackly and distorted when you turn it up? That's what the speakers in my door sound like.
ANY SUGGESTIONS?
Old Apr 28, 2008 | 08:12 PM
nox1s's Avatar
ANY SUGGESTIONS?
might be the bass making the plastic rattle or creak.. the cheap plastic in our cars (sad but true) makes terrible creaking noises..
Old Apr 29, 2008 | 05:12 PM
iuhoosiers's Avatar
Gasp! Sacralig!
Old May 28, 2008 | 08:01 PM
smokey847's Avatar
I think i've pinpointed the crackle to be coming from the passenger side tweeter. Is there anything I can get done under factory waranty about this?
Old May 28, 2008 | 08:18 PM
SRT6nTulsa's Avatar
It's not the tweeter. Take the door handle/tweeter trim panel off. Apply felt. Reinstall. The squeak will go away.
Old May 28, 2008 | 08:25 PM
smokey847's Avatar
Are there any instructions to do so? I'm kind of new to taking apart cars.
Old May 28, 2008 | 08:35 PM
SRT6nTulsa's Avatar
I'm TDY right now. I don't have pics. The trim piece that goes around your door handle and the tweeter......take it off. Then listen for squeaks. If they stop, applying felt will eliminate squeaks after you reinstall the piece. (Mine was so bad, when I would press on it, it would squeak like fingernails on the chalkboard.)
Old Jun 3, 2008 | 11:01 AM
thackstonns's Avatar
I had the door rattle on the right side also. I took the ring and grill off and tightened the screw. It was still rattling so I proceeded to push down on various spots to see where it was coming from. Right where the webbing for the side pocket meets the speaker enclosure is where it was coming from. I was not sure what to do cause it seemed tight. finally I pushed pretty hard to see just how far it would have to come in to stop the rattle. It clicked. and no problems since. Now if I were to guess before hand I would have said it was snapped all the way in. It didnt seem like it was loose at all. But it must have been. Just thought it might help someone else.
Old Jun 4, 2008 | 08:31 PM
smokey847's Avatar
Could someone please post how to remove this panel the proper way without damaging anything?
Old Jun 4, 2008 | 08:37 PM
nox1s's Avatar
It isn't being held on anything besides clips, carefully just pry it off..
Old Jun 16, 2008 | 04:10 PM
smokey847's Avatar
Alright. I popped that panel off today, put a square piece of felt (about 3"x3") behind the protrusion on the plastic piece that goes back into the door. From listening to it for about 5 minutes, THERE IS NO MORE RATTLE! Thanks for everyone's help!
Old Jun 17, 2008 | 03:22 PM
smokey847's Avatar
Just kidding. I listened to the sterero with my iTrip today and the crackle is STILL THERE!!! I just don't know what to do. It's driving me nuts. I'm beginning to think the tweeter is busted or something!? Any help!?
Old Jun 17, 2008 | 03:48 PM
spensley's Avatar
Talking Re: Easy Fix: Door Speaker Rattle
Maybe it's just your hearing!!!
Whack your self on the side of the head really hard and see if anything falls off/out.
Old Jun 17, 2008 | 06:27 PM
nox1s's Avatar
Does it sound like it moves? One time it'll sound like the tweeter, then the speaker.. then the dash... IDK.. maybe it's me going crazy but oh my god this is so annoying..!
Old Jun 17, 2008 | 08:35 PM
smokey847's Avatar
Lol. It's one of those things that I'm sure no one else would notice, but it just really REALLY bothers me. But, no it doesn't sound like it moves other than not exactly being able to pinpoint where on the door it's coming from. I think this is true with all cars. I guess I'll have to learn to live with it...
Old Jun 17, 2008 | 08:50 PM
SRT6nTulsa's Avatar
The speaker grill assembly itself will rattle. I glued the rubbing plastic pieces together.
Old Jun 17, 2008 | 10:22 PM
antonio311's Avatar
Guys do the crossfires have rear speakers???? and also do they have a balance control from front to rear? I know they have the left to right control. How about front to rear?
